996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
Exelzion
PostPosted: Wed May 16, 2018 7:47 am    Post subject: rear and front bumper question Reply with quote
Hi I’m just wondering would the 996 turbo front bumper and rear bumper fit the 02 carerra 4? I know it fits the 4s widebody but will it fit the c4? If not, Is there any adaptions that can be done , or anyone with any experience who has tried it ? Thanks guys
Porsche - There is no substitute!
----- Porsche 994
1998 Porsche 2.5 Boxster
1998 Porsche 3.4 Carrera 2
2005 Porsche 3.8 Carrers 2S
2002 Porsche 3.6 Carrera 4
PostPosted: Wed May 16, 2018 8:13 am    Post subject: Reply with quote
Design 911 used to sell a 'turbo style' front bumper Thumb
PostPosted: Wed May 16, 2018 8:44 am    Post subject: Reply with quote
Speak to this member:
http://www.911uk.com/viewtopic.php?t=127851&highlight=
Looks like the turbo bumper to me Thumb
alex yates
PostPosted: Wed May 16, 2018 8:52 am    Post subject: Reply with quote
Rear one won't unless you widen the bodywork on the rear.
Thomp1983
PostPosted: Wed May 16, 2018 9:34 am    Post subject: Reply with quote
I've looked into his for the future, front will fit straight on but you need to cut the ends of the front impact bar so they don't show through the grills.
The rear needs cutting and narrowing, any decent body shop can do it but it's not cheap as its labour intensive
Stoo.c
You would need to change the rear lights as well and they aren't cheap.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
Stuart Mackay
PostPosted: Wed May 16, 2018 10:22 am    Post subject: Reply with quote
Just fitted a turbo/c4s to my C4 Cab.
In addition to the bumper, you need the Turbo/C4S front wheel liners (they are vented and different shape to the standard 996 which marry up with the centre radiator lower ducting (also required) as well as all the fixings.
I have part numbers if required.
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
 Filesize:  86.97 KB
 Viewed:  1019 Time(s)
Exelzion
PostPosted: Wed May 16, 2018 10:27 am    Post subject: Reply with quote
Thanks going to buy a 996 front turbo bumper today for 500 so any help part numbers would be great Fitting to my 996 c4 2002
----- Porsche 994
PostPosted: Wed May 16, 2018 10:58 am    Post subject: Reply with quote
Saw this car on FB thumbsup
You do valeting, that correct Dont know
Unless someone has nicked your photos that is Grin
Exelzion
PostPosted: Wed May 16, 2018 11:47 am    Post subject: Reply with quote
Part numbers would be brilliant !!! Thanks a lot
----- Porsche 994
Stuart Mackay
PostPosted: Wed May 16, 2018 4:14 pm    Post subject: Reply with quote
I can clean a car ok, but relied on Harry Morton to mop the car and wax it the other evening.
He does a great job at very reasonable prices. He is based in Norfolk and can be conatcted here:
https://www.facebook.com/MPvalet/posts/584322935266496?comment_id=584440608588062&reply_comment_id=584451251920331&notif_id=1526392244829101&notif_t=feed_comment_reply&ref=notif
Re part nos, suggest you phone Saffron Hill at Porsche Colchester and she can supply everything you need:
The turbo/C4s wheel liners are
996.504.123.00
996.504.124.00
@ £76.44 + VAT each
Dont let them send you the .03 parts , they are for the C2 & C4 !
The centre rad air duct is 996.575.161 @ £57.22 + VAT
Probably best to get some more expanding rivets and self tapping torx screws too as they will be eithe missing/rusty or break when you try and get them out.
The liner rivet holes dont line up with the C2 or C4 rad brackets in the wheel well, so you will either have to replace rads and mounts or drill the liners to suit the existing brackets.
Reassemble with lots of waxoyl to keep corrosion in the area at bay.
Exelzion
PostPosted: Wed May 16, 2018 8:41 pm    Post subject: Reply with quote
Thanks so much mate I’ll be doing that after my new exhaust in few weeks, thanks again brilliant Thumb
----- Porsche 994
