996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
madams91
PostPosted: Tue May 15, 2018 6:03 pm    Post subject: Trunk Battery Light Reply with quote
Evening Folks,
I want to trickle charge my battery for a few days leaving the battery left in the car.
Is there any way to turn off the trunk light? i have checked the fuse but can't see the diagram leads to the trunk light.
Any advice much appriciated.
kind regards
Mark
Magic919
PostPosted: Tue May 15, 2018 6:07 pm    Post subject: Reply with quote
The car dealer trick is remove the bulb.
Something tells me it goes off after an hour or two.
997.2 C2S PDK
997.2 C4S PDK
madams91
PostPosted: Tue May 15, 2018 6:15 pm    Post subject: Reply with quote
thank-you for your help i'll see if it goes off!
lofi
2001 Porsche 996 Turbo
PostPosted: Tue May 15, 2018 6:46 pm    Post subject: Reply with quote
I find the frunk closes fine with the trickle charge cable coming out of it
LoFi
996 turbo tip
ex 944 2.5 manual
ex 964 C4 manual
PostPosted: Tue May 15, 2018 6:52 pm    Post subject: Reply with quote
Push the lock closed with a screwdriver .
