996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
jibm
PostPosted: Tue May 15, 2018 9:24 am    Post subject: headlamp out to change brakes? Reply with quote
hi all
I'm having a brake fluid change and some braided hoses fitted to my C2S the car went in on Friday, should have been back the same day. however, the garage called me to say that front two brake pipes where the braided ones meet on the car side needed changing as the unions are old and corroded so they need to fit new genuine pipes, which is understandable. I’m told my car will be ready Monday. Monday come and the pipe’s arrived late so not ready.
I happen to be passing this morning, so I pop in to take my service book in to get them to stamp the brake fluid change etc.
When I get there I see my car with the wheels on sitting on the ground and it got the NSF headlamp out!……so my question is, is there any reason to remove the headlamp to change the pipes? Which has made me quite suspicious that perhaps they have broken it?
I’m quite mechanically minded and if it wasn’t for lack of time I would have probably done the job myself, and I can’t think why the headlamp would come out!
Has anyone done this job? And need to take it out?
Thanks in advance
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue May 15, 2018 9:47 am    Post subject: Reply with quote
Yes there is a union thing right behind the headlight tucked up behind the wheel arch.
Thats were the pipes for the NSF OSF and rear all come together.
They will have removed the headlight for better access as its awkward from in the wheel arch.
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
wasz
PostPosted: Tue May 15, 2018 9:52 am    Post subject: Reply with quote
You can see it here, right above the arrow for the trunk release cable with the 2x front black brake lines coming out. The one (or two if PASM) for the rear go up around the top of the arch.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue May 15, 2018 10:01 am    Post subject: Reply with quote
Here it is shown from the headlight side.
jibm
PostPosted: Tue May 15, 2018 10:07 am    Post subject: Reply with quote
Great thanks thats put my mind at rest
PostPosted: Tue May 15, 2018 7:51 pm    Post subject: Reply with quote
Not wishing to be rude here but there does seem to be a lack of trust between you and the garage .. its always best to ask them . if you get an answer you dont like then please ask here but from my own experence then the bond of trust is essential to a working relationship and dealing with the garage first is paramount.
i only say this as i work in the trade on these and if your not sure of what a garage is upto and are not sure / happy with them then see what others are in your area ... build up a trust factor .. we are not all bad !
