996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
bullet7
PostPosted: Mon May 14, 2018 5:58 pm    Post subject: Centre Console Query Reply with quote
The cubby box lid on my car won't stay shut, even if slammed, does anyone know if the catch is adjustable or is it a replacement lock?
2004 996 C2 Cab
PostPosted: Mon May 14, 2018 6:47 pm    Post subject: Reply with quote
looks to me like no. 20 here ..
https://www.deroure.com/diagrams.asp?MAK=3&MDL=25&TBL=2663&SMA=&SMO=0&ST=&SC=0
Try useing a screwdriver to lock it , if it doesnt work with that then a new lock i suspect .. if not perhaps the hook isnt going down far enough .. cant remember if theres any rubber bungs on the 996 cubby lid .. there are on a 997 .
Either way unless the lock is loose ( and its worth checking that ) theres not an adjustment that i remember seeing im afraid ... but i now need to look at one to check .. sigh .. another thing on my list of to do's Very Happy
bullet7
PostPosted: Mon May 14, 2018 7:55 pm    Post subject: Reply with quote
Cheers Demort. It only started yesterday and I didn't get a chance to have a proper look at it. I wondered if it was a common problem, but I guess not. Only way I'll find out is to take it off the console.
2004 996 C2 Cab
Paynewright
PostPosted: Tue May 15, 2018 6:14 am    Post subject: Reply with quote
I had a similar thing with the ash tray lid. Had a good look at mechanism and it was partly worn but mostly dirty. Good clean up and carefully applied lubrication (silicon grease with cocktail stick) and all works well.
Ian
bullet7
PostPosted: Tue May 15, 2018 5:42 pm    Post subject: Reply with quote
Thanks both for your input. I think I will have a really close look at it this weekend. Could be just clogged as you suggest Ian.
2004 996 C2 Cab
