996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Chris_in_the_UK
Estoril
PostPosted: Tue Jan 15, 2019 4:32 pm    Post subject: Reply with quote
Hooner wrote:
alex yates wrote:
You must be crackers removing a good bearimg and fitting an unknown dual row. The failures were mainly due to bearing tolerances. You NOS bearing may be one of the ones that go pop.
im not removing it yet, i'm gathering parts for a future overall the new on will be fitted without the oil seals if and when required. I new stronger retaining shaft would be fitted too if i can locate one?
Have to agree with Alex here - did you read Baz's point below?
The bearing size of the small bearing is basically to small for the job and whether it is a single or double ball bearing, or a roller bearing (that will not resists the significant side loading that chain flap causes) the only reliable alternative to fit in situ is a solid bearing with separate oil supply.
2006 Cayman S PCCB's
alex yates
PostPosted: Tue Jan 15, 2019 4:38 pm    Post subject: Reply with quote
Still crackers fitting a bearing with a known manufacturing defect when the one already in is fine.
alex yates
PostPosted: Tue Jan 15, 2019 4:39 pm    Post subject: Reply with quote
If you are doing an engine rebuild, go for the larger bearing option Hartech offer.
alex yates
PostPosted: Tue Jan 15, 2019 4:49 pm    Post subject: Reply with quote
To quote:
bazhart wrote:
The difficulty here is that some bearings were fitted a bit tighter than others (usual manufacturers tolerance build up) and these generated more minute running in metallic particles that mixed with grease and formed grinding paste that prematurely damaged some bearings.
This is why they either seem to fail early (under 45K) or last well over 100K.
Baz
Fitting a NOS sticks you right in the middle of this ball(bearing) park.
Hooner
Baz states that the retaining shafts are weak due to the oil seal in it, and can snap or fracture on removing them is a new one available? the new bearing without the seals no doubt will be fine as we know failures of these are quite rare.
911 a way of life!
Hooner
PostPosted: Tue Jan 15, 2019 4:55 pm    Post subject: Reply with quote
alex yates wrote:
To quote:
Baz
No doubt this will not happen with the seals removed, im not sure if it is nos now or just new as it has no seals but it is the correct size.
911 a way of life!
alex yates
PostPosted: Tue Jan 15, 2019 5:53 pm    Post subject: Reply with quote
Seals have no bearing on races manufactured to the extremes of their tolerances.
Are you sure it's a dual row as nobody manufactures them at those sizes?
Hooner
PostPosted: Tue Jan 15, 2019 6:32 pm    Post subject: Reply with quote
yes it's a dual row 20x47x23.8 with polyamide cage. looks good.
911 a way of life!
alex yates
PostPosted: Tue Jan 15, 2019 7:40 pm    Post subject: Reply with quote
Hooner
PostPosted: Tue Jan 15, 2019 7:57 pm    Post subject: Reply with quote
so back to is there a stronger retaining shaft available to fit or is a new one obtainable . Dont know
911 a way of life!
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Jan 15, 2019 9:19 pm    Post subject: Reply with quote
I have one fitted in mine from Hartech but I'm unsure if it'll fit a dual row bearing. They only supply the post with bearing and ideally like to fit it themselves but only with the IMS on the bench. You would have to sweet talk them if there was a chance of them selling one individually.
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Tue Jan 15, 2019 9:23 pm    Post subject: Reply with quote
if you look on hartech website for rebuild costs there are the following options :
New Latest Design Porsche Intermediate Shaft: From £800 + VAT
New Intermediate Shaft Bearing & Stronger Spindle: £150 + VAT
Fitted to intermediate shaft from stripped engine.
Hooner
PostPosted: Wed Jan 16, 2019 9:13 am    Post subject: Reply with quote
Ok thanks for the replies guys, does anyone know if its possible to knock the retaining shaft though the back of the bearing then use a internal puller to remove the bearing,this could save the retaining shaft from any damage Question
911 a way of life!
wasz
PostPosted: Wed Jan 16, 2019 11:05 am    Post subject: Reply with quote
You probably could knock it through, but in doing so puts stress on an apparently weak part.
I wouldn't bother doing anything.
The risk of IMS bearing failure is really low.
Theres so many other things that could let go at this age and mileage, why disturb the bearing and increase its risk of failure?
I would either: leave well alone and flip the seal off when the clutch needs doing
Or: fully rebuild the engine now, new bearings, chains, with hartech IMS mods, the lot, this will remove all the other points of failure and give you real peace of mind.
Mine:
alex yates
PostPosted: Wed Jan 16, 2019 11:31 am    Post subject: Reply with quote
+1!
Hooner
PostPosted: Wed Jan 16, 2019 12:20 pm    Post subject: Reply with quote
I get the hartech rebuild thing but, as im in Northern Ireland its not really an option, so im just gathering parts if they are needed,the bearing will only be changed if on inspection it's showing signs of wear.
911 a way of life!
Chris_in_the_UK
Estoril
PostPosted: Wed Jan 16, 2019 4:54 pm    Post subject: Reply with quote
Replacing the bearing in situ is a recipe for disaster TBH.
I would not consider replacing the old dual row with one of the same for reason already mentioned.
Could pallet ship an engine to Hartech?.
kas750
Reims
2006 Porsche 911
PostPosted: Wed Jan 16, 2019 5:00 pm    Post subject: Reply with quote
One member from this site had an IMS bearing replaced in-situ by a well renowned indie from the south and coincidentally the engine lunched on the timing chain a couple of days later!
Good advice offered on this thread mate Thumb
Goto page Previous  1, 2, 3
Page 3 of 3
