996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Bluebird911
PostPosted: Fri May 18, 2018 6:36 pm    Post subject: Reply with quote
If you want to change your IMSB, I would make sure it is carried out by someone experienced in this work.
I'm not recommending them through experience, but the people below seem to have a good reputation on other forums for this work.
https://rpmtechnik.co.uk/servicing/ims-bearing-upgrade/
Google Porsche IMS bearing specialists and a list of respected Indie appear. Other forums could be useful. Try PistonHeads or other Porsche forums for recommendations. Not many recommendations for bearing replacements appear on here.
PostPosted: Fri May 18, 2018 6:54 pm    Post subject: Reply with quote
Hooner wrote:
my car i a 99 3.4 which has the dual row bearing now clocking on 100k the rms is leaking so in the winter i am thinking of changing it, if the ims looks dodgy what could i replace it with? as the dual bearings are no longer available.
Im not getting into the should i or shouldn't i replace it as ive said what i think many times including in this thread .. link here seems to offer duel / single .
http://imsretrofit.com/
alex yates
PostPosted: Fri May 18, 2018 7:40 pm    Post subject: Reply with quote
I'm telling you now - it'll be fine. Just ping the outer seal off the bearing so it spends the rest of its days in fresh engine oil.
Ps. It might be your ims cover plate leaking and not rms. You won't know till you're in there.........and I wouldn't even bother sorting tour leak unless you're having a new clutch fit.
kas750
Reims
2006 Porsche 911
PostPosted: Fri May 18, 2018 7:53 pm    Post subject: Reply with quote
Just warm it up carefully and warm it down carefully and in between cane the arse off it and change the oil regularly.Jobs a good 'un thumbsup
Hooner
PostPosted: Fri May 18, 2018 11:30 pm    Post subject: Reply with quote
thanks for the link much appreciated.
Hooner
PostPosted: Fri May 18, 2018 11:31 pm    Post subject: Reply with quote
Thats the plan its just incase its knackered. Thumb
Cybot7
2001 Porsche 996 Carrera 2
PostPosted: Tue May 22, 2018 11:41 am    Post subject: Reply with quote
Mine is an early 2001 3.4 but I don't know whether it has a single or dual roller bearing. I was wondering if it's taken out and it's found to be perfect is it advisable to get a new one or stick the old one back in? I guess having gone that far it's best to stick a new one in as the bearing itself isn't that expensive or so I've been lead to believe. I'm easily lead btw Wink
Nothing is foolproof to a sufficiently talented fool
alex yates
PostPosted: Tue May 22, 2018 12:20 pm    Post subject: Reply with quote
You will have the dual row. You don't need to remove it to check it. Pulling the bearing out in situ can do damage to other engine components like chain guides. Have it checked, remove the outer seal and then leave well alone.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue May 22, 2018 12:35 pm    Post subject: Reply with quote
I looked at mine recently, 130k 3.4 MY99
I was replacing the clutch and flywheel (on my back on drive in the snow).
Locked the cams with a homemade tool and whipped the tensioners out for new seals.
Whilst there I took the IMS bearing cover off and inspected the bearing.
Mine felt like new, no roughness, no play, just buttery smoothness. I removed the bearing seal and old oil came out, I left it off as Alex says it will now get effectively fed new oil all the time.
Used loads of blue sealant on the cover going back and popped in the latest RMS whilst I was there.
Cybot7
PostPosted: Wed May 23, 2018 5:51 am    Post subject: Reply with quote
Thanks. As I'm not a mechanical genius can this be done with the engine in situ and without removing the clutch assembly?
alex yates
PostPosted: Wed May 23, 2018 6:54 am    Post subject: Reply with quote
Can only be done with your gearbox & clutch off but with engine in. Just wait till you have access there for a clutch, etc.
Cybot7
PostPosted: Wed May 23, 2018 6:56 am    Post subject: Reply with quote
Thanks, Alex. As it's only done 30k I think a new clutch is some way off.
alex yates
PostPosted: Wed May 23, 2018 7:36 am    Post subject: Reply with quote
1st new clutch on mine was around 40k.
Cybot7
PostPosted: Wed May 23, 2018 7:54 am    Post subject: Reply with quote
About two years to go for me then Very Happy
911munKy
PostPosted: Wed May 23, 2018 8:25 am    Post subject: Reply with quote
You can fit a standard single row bearing and make up a spacer athough I like the look of this dual row bearing which should be better (although maybe not as good as the original dual row bearing Dont know I’ve not heard of anyone fitting it so I think you should be the guinea pig).
https://www.onlinebearings.co.uk/3204-ATN9C3-SKF-Double-Row-Angular-Contact-Ball-Bearing-Polyamide-Cage.html
2000 C2 996
bazhart
Approved Trader
PostPosted: Wed May 23, 2018 10:57 am    Post subject: Reply with quote
The difficulty here is that some bearings were fitted a bit tighter than others (usual manufacturers tolerance build up) and these generated more minute running in metallic particles that mixed with grease and formed grinding paste that prematurely damaged some bearings.
Most however were OK.
The grease gradually escaped because when hot it is very thin and at that point it depends how worn the seal is as to how much engine oil can seep back in to protect the bearing.
This is why they either seem to fail early (under 45K) or last well over 100K.
Unfortunately the small spindle shaft that holds it all together has a machined recess in it for an "O" ring and this makes it weak in bending.
When you remove the spider to inspect or remove and replace the bearing - even with the chain tensioners removed at the right crankshaft angle to avoid chain timing slip - the tension in the chain makes the bearing sit out of line with the hole it has to fit into and the sideways pressure needed to align it is often applied by bending loads on that weak spindle making it likely to metal fatigue in the future.
Furthermore the bearing hole will have picked up metallic deposits (compaction) so after removing the old bearing it may not be perfectly round so this needs inspecting and measuring before a re-fit and if unsuitable remedial work may be needed.
Because most early failures have already occurred by now and because it can do more damage by trying to replace a bearing - the statistics show absolutely that leaving it alone is p roving a cheaper option than trying to replace it in situ.
This will of course not stop a small number of unfortunate owners still having a failure but it is better overall for us to give advice that applies to and benefits the vast majority than that which would make more of them suffer as a result.
The bearing size of the small bearing is basically to small for the job and whether it is a single or double ball bearing, or a roller bearing (that will not resists the significant side loading that chain flap causes) the only reliable alternative to fit in situ is a solid bearing with separate oil supply.
Since many engines will need a rebuild at higher mileages and we can then fit the larger bearing (without seal) either a Porsche one or our own remanufactured version (which is made with both Hivo and roller chain drives so suits older cars as well) this adds to the advice that generally and statistically it might be better to leave alone than try and inspect it (unless there are obvious signs of failure of course).
If there are obvious signs that something needs to be done and the owner cannot afford an engine rebuild then the risk of replacing the bearing in situ has to be born and in those cases we have an alternative available.
We have had to replace many other "replacement" designs that had grand claims associated with them but never a solid bearing version (although they are much more expensive).
It is sad that less help was not forthcoming from Porsche and the many independents that have tried their best in good faith to provide a solution should not be berated if they do not always work as well as they hoped. If Porsche could not get it right it is a bit much to expect small independents to.
A single bearing has just as much load rating as a double row because the internal tracks are narrower in a double row and so either are similar in rating.
There are different ball bearing types and suppliers and they come in different specifications and tolerances and the right one to use relates to the original clearances and tolerances Porsche made the parts to and should allow for age deformation of the bearing housing and compaction etc.
My own personal view is that with all older Porsche's following the traditional trend of eventually increasing in value and with less petrol sports cars likely to be around in years to come and with properly rebuilt engines (and properly designed and developed oversized versions becoming available) it might be better to consider that route and fix the IMS problem at the same time and for posterity.
Sorry to repeat that none of this advice will prevent some poor soul somewhere having a failure - it is a small risk factor that was not caused by the independents and there are plenty of alternatives to consider.
Sorry there is not a simple solution.
Baz
Click here for the Hartech
www.hartech.org
Kingb4
PostPosted: Wed May 23, 2018 12:28 pm    Post subject: Reply with quote
Excellent post Baz - I think we all appreciate your input.
I for one am following your advice (am on 80k and original IMS - as far as I know). I accept the risk (small) I am running, based on the statistics.
2002 996.2 C2 Cabriolet
Hooner
PostPosted: Tue Jan 15, 2019 3:53 pm    Post subject: Reply with quote
I have gotten hold of a nos double row ims bearing and am wondering if there is a stronger shaft it sits on available any where? or a new one incase it breaks whilst trying to remove it. Question
911 a way of life!
alex yates
PostPosted: Tue Jan 15, 2019 4:06 pm    Post subject: Reply with quote
You must be crackers removing a good bearimg and fitting an unknown dual row. The failures were mainly due to bearing tolerances. You NOS bearing may be one of the ones that go pop.
Hooner
PostPosted: Tue Jan 15, 2019 4:30 pm    Post subject: Reply with quote
im not removing it yet, i'm gathering parts for a future overall the new on will be fitted without the oil seals if and when required. I new stronger retaining shaft would be fitted too if i can locate one?
911 a way of life!
Page 2 of 3
