996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sat May 12, 2018 5:39 pm    Post subject: HVAC cables relocate Reply with quote
Had a crack at doing the hvac relocate this morning but it's got me stumped I think I will have to take out the lower cage entirely? The various guides have glossed over rerouting the cables or not pictured it, has anyone seen a really comprehensive photo guide not lost to photobucket or a you tube video ideally?
alex yates
PostPosted: Sat May 12, 2018 6:05 pm    Post subject: Reply with quote
I found that bit quite easy. What's your actual problem?
asterix_the_gaul
PostPosted: Sat May 12, 2018 6:34 pm    Post subject: Reply with quote
Yes this is what all the guides seem to say...
Getting the cables and plugs down- they won't fit anywhere: some guides say disassemble the side carpet bit and the heater trunking, but unclear which side as it was a US car, others have said it just pops down the back. Certainly won't in mine So I take out the whole lower plastic cage ?
alex yates
PostPosted: Sat May 12, 2018 7:23 pm    Post subject: Reply with quote
Take the side leather trim and carpeted trim off the passenger side of the centre console. They just clip on. You'll then have better access.
asterix_the_gaul
PostPosted: Sat May 12, 2018 7:28 pm    Post subject: Reply with quote
I pulled off both the leather ones already that was no better so I'll see if the carpet one helps Next Week when I get a chance. Thanks Alex
asterix_the_gaul
PostPosted: Sun May 13, 2018 11:38 am    Post subject: Reply with quote
Spot on Alex, once I tugged off the passenger side carpet console trim it was a piece of cake to pull the cables through and route them.
Just can't get the a/c controls to fit in the lowest position as there doesn't seem to be slots to allow the hvac side rails to slot in to so it doesn't sit in by about 8mm. Grr!
alex yates
PostPosted: Sun May 13, 2018 2:35 pm    Post subject: Reply with quote
You're supposed to remove the side rails......if I'm right in what you're talking about.
asterix_the_gaul
PostPosted: Mon May 14, 2018 8:36 pm    Post subject: Reply with quote
So I thought the AC controls are supposed to slot directly in to the lowest slot without modification?
I think it's the side rails you can see on the image stopping it going in but they would require a dremmel to remove this can't be right??
 Filesize:  7.77 KB
 Viewed:  675 Time(s)
alex yates
PostPosted: Mon May 14, 2018 9:16 pm    Post subject: Reply with quote
Looks like a Different HVAC to mine. Mine doesn't have those rails down the side I don't think. See photo:
