Water trap - base of A-pillar
9xxnick
29 Jul 2014
310
I'd not noticed this before, but there's a depression at the base of the A-pillar which is big enough to hold 30 or 40cc of water. There's a drain-hole, of course, but these can get blocked over time.
You can only see the depression with the door open, and then you'll probably need to aim a torch at the aperture between the door and the based of the pillar.
Might be worth checking to see if yours is flowing freely! I used a length of sheathed copper wire from a twin and earth to poke the drain-hole through, which has resulted in any water flowing out easily.
Pics would be handy please!
This is the area.
The leading edge of the offside door is to the left of the picture. The water sits in the area underneath where the bolt can be seen coming through the panel on the right. It's the slightly brighter area in the photo.
The drain-hole's the curved dark spot at the point of the depression that's closest to the centreline of the car.
The photo's slightly confusing because you can see a reflection of the inner part of the wing in the door skin to the left, but ignore that and focus on the base of the A-pillar area.
Hi 9xxnick,
Just went out to my car and opened the door and pointed a torch down between the door and the A pillar. I can see a small drain hole at the bottom as shown in the picture with the black arrow. Is this what you are talking about?
ATB :)
Yes, although your drainhole looks to be bigger and in a slightly different position than mine, albeit not by much. It doesn't look like you have anything to worry about there though.
:thumb:
ATB :)
Thanks for the pics folks, will take a look.
124,556
1,441,489
48,969
Stulees65
