996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
911_AS
2012 Porsche 991 Carrera S
PostPosted: Mon May 07, 2018 6:17 pm    Post subject: Engine Squeal when shutting off Reply with quote
When switching off the engine, regardless of the engine temperature, my car is making a strange squealing sound, which I've never noticed before (on this, or any of my previous 911's).
Any ideas on what this could be? (Sound occurs at 0:04s, you'll need to listen carefully though!)
Open Youtube Page
NOTE: it has recently returned from an OPC, following some Intermediate Service works. Red Herring, or a direct correlation??? Hmm...
991.1 C2S. 2012. Basalt Black. PDK.
997.2 C2S. 2010. Meteor Grey. PDK. SOLD.
997.1 C2S. 2006. Basalt Black. Manual. SOLD.
Naturally Aspiring.
PostPosted: Mon May 07, 2018 6:29 pm    Post subject: Reply with quote
Sounds like a PSE valve thats a bit " dry" or possibly faulty ... im going with a bit of lub and it will be fine .
If you Dont have PSE then im not going to come back here Razz
911_AS
PostPosted: Mon May 07, 2018 6:34 pm    Post subject: Reply with quote
Thanks mate.
I do have PSE, so your theory could be correct.
Does the valve get dry frequently? And if so, can the lubricaton be done by anyone, or does it need to go back to an OPC? (My Car does have a warranty anyway).
Naturally Aspiring.
PostPosted: Mon May 07, 2018 7:18 pm    Post subject: Reply with quote
Answered your Pm .
ive not come across this before but its what it sounds like to me .
A visual inspection of the valve is best along with a bit of lub to prove it .
Under warrenty and i would leave it to them to sort out although to be honest .. Porsche warrenty and exhaust systems dont go well together .. they kinda refuse .
911_AS
PostPosted: Mon May 07, 2018 9:47 pm    Post subject: Reply with quote
Thank you.
I'll make some enquiries. They can't refuse this one - the noise wasn't there when it went in, and it was there when it came out - simple.
Whatever the actual fault may be, there should be no reason they refuse to fix it.
Naturally Aspiring.
911_AS
PostPosted: Wed May 30, 2018 9:02 am    Post subject: Reply with quote
DeMort - you were spot on, thank you. The PSE valve needed a little lubrication, and now the car sounds fine.
Interestingly enough, OPC did say this is strictly not covered by the Warranty, so the fix was done as a courtesy. I definitely would have challenged this if they wanted £££'s to fix it, given the fault was not there prior to the Interim Service.
The car is 100% fine now and is driving rather superbly.
Thanks again. Thumb
Naturally Aspiring.
PostPosted: Wed May 30, 2018 6:16 pm    Post subject: Reply with quote
Im afraid Exhausts are not covered by warrenty these days so it would have been the OPC paying for the repair ..
Which and lets be fair here was good of them .. OPC,s get plenty of stick so something like this is good customer service .
Remember i said .. how can i explain a feeling .. with a result like this is the answer Very Happy
Fixed .. excellent Thumb
911_AS
PostPosted: Thu May 31, 2018 5:07 pm    Post subject: Reply with quote
I understand that PSE's are not covered by Warranty, however, my point was that the issue was not there before it went in, but was there after, so by sheer logic something must have happened whilst under their care, to cause the issue.
I do agree with you completely, however. The OPC (East London) in this situation have been excellent, and I cannot fault them. The service from start to finish was great, and I would use them again if I had to.
Your "feeling" was spot on mate - trust thy instincts. Smile
Naturally Aspiring.
