996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Donx22
PostPosted: Mon May 07, 2018 11:31 am    Post subject: Stainless rear bumper supports?!? Reply with quote
As the title says.... anyone one know where I can get new rear bumper supports in stainless?
I believe a member on here makes them but I’m searing with no luck!
My larger supports , well one is corroded have through and doesn’t even attach to the bumper and the other is basically trash also. The 2 small ones are looking the same way...
Ideally need a set ASAP as I’m battening currently with taking the bumper off, all screws are corroded through and I’m going to have to drill a couple out. I figured no point replacing with new that will do the same in the end.
If anyone is aware who or where I can buy them from that would be greatly appreciated!
Code:
Endoman
PostPosted: Mon May 07, 2018 11:42 am    Post subject: Reply with quote
I'm in the market for 2 sets if available.
cableguy
PostPosted: Mon May 07, 2018 9:52 pm    Post subject: Reply with quote
orangecurry is the man for these iirc. Might be worth a PM. Thumb
C.
Pork!
Endoman
PostPosted: Tue May 08, 2018 8:29 am    Post subject: Reply with quote
You may have to contact OC through Rennlist or Tipec forums. Forgot he did them.
RobIpswichUK
1994 Porsche 993 Carrera 2
PostPosted: Tue May 08, 2018 9:35 am    Post subject: Reply with quote
I have a pair. Might see if a chap local to me could knock up a few and what the cost would be.
Rob
'94 C2 Iris Blue (+ White Stripes!) Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230 lowered + AMG wheels)
Range Rover Sport V8 (L320 chipped)
TT Roadster (standard - wife’s daily!)
W211 E320CDI Barge (must not forget - NEED TO SELL!)
E91 320d SE Touring (must not forget - NEED TO SELL!)
cableguy
PostPosted: Tue May 08, 2018 11:32 am    Post subject: Reply with quote
I'd certainly be interested in a pair if it helps with numbers. Thumb
C.
Pork!
crash7
PostPosted: Tue May 08, 2018 11:35 am    Post subject: Reply with quote
Are these a common part between 993 & 964?
If they will fit a 964 I would also be interested in a set. - I hate rust!!
Endoman
PostPosted: Tue May 08, 2018 12:35 pm    Post subject: Reply with quote
Not the same unfortunately and 4 for the 993, 2 for the 964. Only the simple one was made in s/s and N/B iirc. Turbos and w/b are different. Only thing in common is they all rot.
Donx22
PostPosted: Tue May 08, 2018 8:13 pm    Post subject: Reply with quote
Thanks guys, I’ve sent him a message on here and will do on rennlist!
Fingers crossed he can still get them made!
I will let the others guys interested know if I hear back anything!
Much appreciated
Donx22
PostPosted: Sat May 12, 2018 5:51 pm    Post subject: Reply with quote
Anyone manage to get hold of him... I’ve had no luck myself. May have to go standar route Confused
Pretzel
PostPosted: Mon May 14, 2018 8:57 pm    Post subject: Reply with quote
Good idea Rob, looks like there is a demand.
993 C2 Aventura
RobIpswichUK
PostPosted: Thu May 17, 2018 2:56 pm    Post subject: Reply with quote
I'm finally back home this weekend so should get a chance to pop them over for at least a rough quote (fingers crossed).
Rob
tim993
2016 Porsche Boxster 981
PostPosted: Sun May 20, 2018 9:35 am    Post subject: Reply with quote
Buy new from Porsche and have them powder coated before being fitted. Then, where possible replace fixings with stainless nuts / washers etc.
Anything to help put off the ghastly rust 😀
"I don't know what it is about peace conferences, but they always seem to attract terrorists, extremists and nutterists."
1995 993 turbo
