996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
DerbyJim
PostPosted: Fri May 04, 2018 9:34 pm    Post subject: 991.1 PCM Reply with quote
Just collected my new to me 991.1 GTS in Carmine Red. Flippin’ eck it’s LOUD!
One quick question for now, how do I play my music from my iPhone? I thought I could just plug in my phone via a cable to the glovebox and press play but no joy.
You could tell me to RTFM but I’m having too much fun driving it at the moment! Grin
Photos to follow soon!
G2
PostPosted: Fri May 04, 2018 9:47 pm    Post subject: Reply with quote
Yes. Press "media" button. It will scroll through devices..worth copying content to the internal drive in the pcm as well.
also worth downloading the Porsche Good to know app.
997 Gen2 Turbo S - Speed.
991 C4S - Riviera.
cambsguy
2012 Porsche 991 Carrera S
PostPosted: Sat May 05, 2018 12:32 am    Post subject: Reply with quote
didn't realise you can copy onto the internal drive, how do you do that?
White 991 C2S
DerbyJim
PostPosted: Sat May 05, 2018 12:52 am    Post subject: Reply with quote
Ooo, never knew about the Porsche Good to know app Thumb
And I noticed that I’ve got a Jukebox on my PCM, woo hoo! Going to copy some music over tomorrow.
Any other gems you care to share that you think aren’t too obvious?
DerbyJim
G2
PostPosted: Sat May 05, 2018 6:22 am    Post subject: Reply with quote
https://youtu.be/Xk8NnENYzOw
991 C4S - Riviera.
G2
PostPosted: Sat May 05, 2018 6:31 am    Post subject: Reply with quote
If pressing “media” does not find the iPod, press “source” instead then select iPod from the list.
If can take a while copying files. And the ignition needs to stay on, so best to copy over during a drive Thumb
Note that the pcm shuts down after a while if the ignition is not on (and started I think).
991 C4S - Riviera.
cambsguy
PostPosted: Sat May 05, 2018 9:07 am    Post subject: Reply with quote
Thank you G2, I don't have juke box on my ppm is that because I have an earlier model or do I need to update.. ?
White 991 C2S
cambsguy
Thank you G2, I don't have juke box on my pcm is that because I have an earlier model or do I need to update.. ?
White 991 C2S
G2
PostPosted: Sat May 05, 2018 10:32 am    Post subject: Reply with quote
Jukebox Looks to have been added from early 2013 but the exact date is unclear. There does not appear to be an option code for it, so must have been standard when introduced.
It will be the usual porsche releasing PCM update after a new car release date...happens a lot. Not a major issue as the usb interface etc will be in your car.
991 C4S - Riviera.
911_AS
PostPosted: Sat May 05, 2018 10:39 am    Post subject: Reply with quote
I'm not sure if JukeBox was standard, or an optional extra. Pretty sure my car doesn't have the option, nor does it have DAB. G2 might be able to confirm this?
Re: the iPhone, you can also playback music via Bluetooth. Just Pair up the devices and select AUX BT from Source.
Note - if you play back via Spotify, you cannot change tracks using the steering wheel column stalk, you have to use the physical button underneath the PCM screen. I 'think' the same goes for if you play back via the native Music app within iPhone, but i cannot be 100% as I always use Spotify.
Physical cable hardwired into the USB port still allows the phone function to pair via Bluetooth, and allows control from stalk.
991.1 C2S. 2012. Basalt Black. PDK.
997.2 C2S. 2010. Meteor Grey. PDK. SOLD.
997.1 C2S. 2006. Basalt Black. Manual. SOLD.
Naturally Aspiring.
