996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
RosieG
PostPosted: Thu Apr 26, 2018 10:21 am    Post subject: Speedline wheels Reply with quote
Hello All,
So after a long search I bought a 1990 C2 in Marine blue - Chuffed to bits!
Anyway, it came with 18inch Speedline wheels and I want to put the originals back on.
Therefore I need to shift the Speedline's. They are unmarked and have done less than 500 miles with Michelin Pilot's fitted. I cant tell they are replica's but I'm told they are.
My question is what they are worth - Ive really got no idea.
If this should be posted elsewhere please let me know.
Cheers in advance
Rosie
PostPosted: Thu Apr 26, 2018 11:23 am    Post subject: Reply with quote
Hi Rosie bye
Try here:
http://www.911uk.com/viewforum.php?f=59&sid=e577a63046716a7a0b955661e30c49a9
Add a few pics too
crash7
PostPosted: Thu Apr 26, 2018 12:16 pm    Post subject: Reply with quote
Are they 3 piece replicas, such as RH or Tramont
http://www.tramont.fr/tramont-jantes_en.html
https://www.rh-rims.com/en/a/p-rad
Or
Single piece Veloce?
http://www.velocewheels.com/veloce36/
cableguy
PostPosted: Thu Apr 26, 2018 3:35 pm    Post subject: Reply with quote
Hi Rosie,
If you can take a good clear pic of the front & rear/inside of the wheel then we should be able to advise on what they are along with their value. Thumb
C.
Pork!
RosieG
PostPosted: Fri Apr 27, 2018 9:12 am    Post subject: Reply with quote
Many thanks indeed for the replies. They are coming off this weekend so will take some pics then.
My guess is that they are the Veloce 3.6 version. Although this is purely based on geographics as they seem to be fairly near to where I bought the car!
Ill get some pics up soon.
Many thanks
Guy
cableguy
PostPosted: Fri Apr 27, 2018 9:31 am    Post subject: Reply with quote
Cool.
A quick check of the bolt fixing head on genuine Speedlines is usually the giveaway, Speedlines have the head stamped as shown in the pic attached. Thumb
C.
Pork!
 Filesize:  159.34 KB
 Viewed:  1912 Time(s)
Gazc2
PostPosted: Fri Apr 27, 2018 9:40 am    Post subject: Reply with quote
Think the bolts on the veloce are "fake" and made of plastic
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
crash7
PostPosted: Fri Apr 27, 2018 9:57 am    Post subject: Reply with quote
cableguy wrote:
Cool.
C.
Your bang on, however I have seen original Speedlines with different bolts, these, the originals, are now almost impossible to get hold of and if you need replacements your forced down the generic M7x35 route.
Gazc2 is right in that the Veloce have plastic dummy bolts, however you can also replace these with actual bolts even though it's only for show as the wheel is one piece.
