997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
brownspeed
PostPosted: Sat May 05, 2018 8:56 am    Post subject: Reply with quote
Q) what is the failure mode of these? i.e. what are the symptoms prior to failure?
My drivers side window seems to be getting slower in operation. I wonder if i'm about to suffer the same fate?
any way of preventing failure? apart from not using the window at all.
2004 997.1 C2S (Hartech rebuilt)
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
PostPosted: Sat May 05, 2018 3:36 pm    Post subject: Reply with quote
No real prior warning .. perhaps a wire grateing type noise... you certainly get that noise when it does fail !
Its a steel cable that normally fails .. rusts through .
If you have noticed its slower than usual then it might be on its way out .. or the runners might just need a bit of lubricateing .
Tin man
PostPosted: Sat May 05, 2018 3:46 pm    Post subject: Reply with quote
Managed to get an aftermarket regulator today from Euro Car Parts. Still no Delivery date from Porsche.
rhino-man
PostPosted: Sun May 06, 2018 11:13 am    Post subject: Reply with quote
What would you lubricate the runners with? Is it easy to get the door card off?
2010 997.2 C4S
2001 996 C2 Convertible
Magic919
PostPosted: Sun May 06, 2018 2:17 pm    Post subject: Reply with quote
All of mine became noisy before failure. Some made a crunchy sound instead of the high pitched scrape.
I’ve managed to pull the window up and get it into place with some grippy gloves on, when it failed in the down position.
997.2 C2S PDK
997.2 C4S PDK
PostPosted: Sun May 06, 2018 3:22 pm    Post subject: Reply with quote
Any aerosol with PTFE in it .. you need a can with the thin pipe on the nozzle then lower the window and spray a small amount so that it runs down the channels.
Not too much as it will end up smearing the windows .. no big deal but youll need to clean it off afterwards.
EDIT ..
The steel cable in the image is what rusts through , if a few strands break then you can hear a grateing noise as it goes through the rollers .
 Filesize:  52.71 KB
 Viewed:  812 Time(s)
rhino-man
PostPosted: Sun May 06, 2018 7:51 pm    Post subject: Reply with quote
My drivers window is noisy at the moment hence the lubrication question so I'll give it a go tomorrow.
2010 997.2 C4S
PostPosted: Sun May 06, 2018 8:00 pm    Post subject: Reply with quote
Its a difficult noise to explain .. its a steel cable made up of a lot of smaller wires .. some of these rust through .. break in other words .. when they go through the rollers they make a cracking grinding noise .. well kinda .
Basically if you have a noise then the chances are its on its last legs .
Without the door car and panel off your not going to be able to prove it and they do tend to fully break pretty quickly .
Lubrication may help if the window is slow .. its not going to help if you have any type of noise that hasnt been there before .
Anything new like a noise usually means theres a problem im afraid .
These days if a customer says something is different i belive them 100% even if i cant find a fault at the time .. you know your cars and something different IS a fault .
rhino-man
PostPosted: Sun May 06, 2018 8:38 pm    Post subject: Reply with quote
Thanks Demort, better get it booked in then as its under warranty.
2010 997.2 C4S
brownspeed
PostPosted: Mon May 07, 2018 9:19 am    Post subject: Reply with quote
Thanks Ian, since posting I have tried that and it has improved its action; no audible graunching noises so maybe its fixed.
2002 TVR Tamora 3.6
Abarth 595
inchyra
PostPosted: Tue May 08, 2018 7:46 am    Post subject: Reply with quote
First sign of trouble on mine was that the window went slightly out of alignment - the rearmost top corner of the glass was just catching on the fixed rear quarter glass when opening the door. Few days later a 'bang' when lowering the window and no more operation!
997.1 C4S X51
G-Wagen 280GE
300SE
500SE
GSX1400
Norton Commando
Goto page Previous  1, 2
Page 2 of 2
