996 : 1997-2005 43
Boxster : 1997- 13
Macan : 2014- 0
The return of Marty Wild
PostPosted: Mon Apr 23, 2018 5:42 pm    Post subject: Dodgy PSE actuator success story! DIY for the win! Reply with quote
Got the dreaded PSE actuator issue, the rod has snapped at the ball joint.
Have looked online in some depth, seen quite a few threads on here about it.
Pretty sure Porker doesn’t sell the 987 ones separately but a 997 one can be fettled to fit.
Any advice or parts welcomed, cheers! May have to weld the one that is on there.
Cayman S 987.1
Last edited by The return of Marty Wild on Sat Apr 28, 2018 6:14 pm; edited 1 time in total
PostPosted: Mon Apr 23, 2018 6:06 pm    Post subject: Reply with quote
Does look like its the same part from this thread on boxanet
http://www.boxa.net/forum/topic/69699-broken-pse-exhaust-valve-actuator/
PostPosted: Mon Apr 23, 2018 7:26 pm    Post subject: Reply with quote
Indeed it does, have seen that thread thanks, Phil.
It might come to trying his method, figured sourcing a new unit or welding to perhaps be a touch easier.
Do you have one by chance, Sir? Laughing
Cayman S 987.1
PostPosted: Mon Apr 23, 2018 7:36 pm    Post subject: Reply with quote
Sorry I havent mate, but it may be worth asking on here as a few guys recently swapped out PSE for aftermarket units in the topgear group guy Thumb
Porky C4s
PostPosted: Mon Apr 23, 2018 8:16 pm    Post subject: Reply with quote
Bought complete valves on eBay, all in stainless work very well and about £40 notes each, just means cutting the original out that’s the negative side of it.
PostPosted: Mon Apr 23, 2018 8:39 pm    Post subject: Reply with quote
Cheers, Phil. Think I read somewhere that TG use the same manufacturer for their switchable exhaust actuators. So could maybe approach them for the part?!
@ Porky - I have seen them, you mean replacing the flapper and everything I take it?! Literally cutting into the exhaust tubing?
Cayman S 987.1
Last edited by The return of Marty Wild on Tue Apr 24, 2018 5:24 am; edited 1 time in total
Porky C4s
PostPosted: Mon Apr 23, 2018 8:51 pm    Post subject: Reply with quote
Yes, it’s a pain but they are good units, I got them welded in mine by PCW and it went really well .
Just a thought, to overcome the issue.
Other thought is a internal threaded swivel joint and run a die down the rod from the original if it’s possible
PostPosted: Mon Apr 23, 2018 8:58 pm    Post subject: Reply with quote
Appreciate your thoughts. There is an example where someone got tricky with a die etc....
Kinda want to only take the bumper off once, but it might be a case of getting my broken one off. Putting the car back together and trying to fix the faulty unit.
A mate of mine is handy with a welder but I’m not sure that’s a suitable fix without home seeing the situation.
Cayman S 987.1
PostPosted: Mon Apr 23, 2018 9:07 pm    Post subject: Reply with quote
Yes give Alex at Topgear in Bridport a call hes very approachable and will do his best to help, let him know your off the forum Thumb
PostPosted: Tue Apr 24, 2018 5:26 am    Post subject: Reply with quote
Pretty sure it was TG, I’ll give him a call.
Cayman S 987.1
PostPosted: Tue Apr 24, 2018 11:22 am    Post subject: Reply with quote
Been on the phone to OPC Cambridge, useless isn't the word. Was unable to find on the system that the 987 Cayman even had PSE as an option. Let alone tell me if I can get the valve actuator as a separate part.
I gave him the 997 part number, it's coming in at £96 incl VAT.
Have spoken to my mate with a workshop/ramp, he reckons we can drop the silencer off and he will be able to weld the rod back onto the cup joint.
Watch this space!
Cayman S 987.1
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Apr 24, 2018 12:20 pm    Post subject: Reply with quote
Worth a try to save £100 less a beer or two for your mate... should weld back together, just give it all a good clean up and lube afterwards.
PostPosted: Tue Apr 24, 2018 12:32 pm    Post subject: Reply with quote
Just went under the car for the first time with someone sat in there to toggle 'Sports' on and off.
Unbelievably, the other actuator isn't working now either. The rod is intact, but when the valve is actuated, it is only moving a tiny bit. Which I think suggests the vacuum feed and diaphragm are most likely working, but something is jammed up and not letting the actuator to do its job.
Very annoying, will get in there at the weekend and check them out. My mate is confident he can weld up the one with the broken rod, just hope we can free up the other one.
Do we think its safest to run around with the PSE off now, so the sticky actuator isn't trying to push against anything. As it stands, I have cable tied the broken rod side so the butterfly is open, but the other one is stuck on shut at the moment.
A right bloody mess in short.
Cayman S 987.1
PostPosted: Tue Apr 24, 2018 12:52 pm    Post subject: Reply with quote
Cheers, Rob. I'm almost more worried about the other side now, swear it was working on Friday.
Spoke to a chap from Tower Porsche in London, he said there's probably some corrosion in the ball joint of the sticky one. If I can pop the joint off the ball and clean up the parts, he reckons it will probably free up. Trick is to not damage the actuator popping the fixing apart.
Cayman S 987.1
Robertb
PostPosted: Tue Apr 24, 2018 12:59 pm    Post subject: Reply with quote
I would keep it switched off for the time being, just to be on the safe side. Do the 987s default to open or closed?
I have times when I am not convinced mine is working as it should (sometimes seems loud even in quiet mode!)... one of those jobs to do as I suspect it needs a good clean up and lube.
PostPosted: Tue Apr 24, 2018 1:10 pm    Post subject: Reply with quote
*Double tap
Cayman S 987.1
PostPosted: Tue Apr 24, 2018 1:14 pm    Post subject: Reply with quote
On the 987/997 era, the PSE defaults to off obviously (except for the first 2 seconds you start the car and there's no vacuum) and the butterfly is closed by the actuator being held under vacuum.
I would then always press 'Sports' and in doing so engage the PSE. When this happens, the system stops producing vacuum and the actuators and butterfly valve default to open.
If that all makes sense?
Cayman S 987.1
PostPosted: Tue Apr 24, 2018 1:16 pm    Post subject: Reply with quote
p.s. John at Tower said don't lube up the ball joint, the extreme temps would only serve to bake the lubricant and make for problems.
Cayman S 987.1
Robertb
PostPosted: Tue Apr 24, 2018 3:47 pm    Post subject: Reply with quote
Oops... too late... gave it all a liberal squirt of GT85 and spray grease a while ago! Embarassed
That said, the exhaust surely can't be hotter than the inside of the engine, and the oil in that copes ok.
PostPosted: Tue Apr 24, 2018 4:35 pm    Post subject: Reply with quote
Yeah, I don’t know what the best advice is on that one.
Cayman S 987.1
