I have discovered few problems with my car today coolant related.
Long story short, my car was parked in garage without oil pan for few days waiting for oil change. On Friday I put car together there was no visible any leak but under car floor was very moisture, strange.... checked coolant, was below minimum on cold engine, since I will be installing LTT I decide to top up with water just to check if something will show up, I have to point out coolant below minimum and no warning on dashboard.
My plan for today was to rush my C4S locally, pull off driveway after all night and discover leak :frustrated:
Start looking under car and leak is visible on middle where splash shields rear to centre are connected. I decide to drive car to garage and solve this problem next week I get to my garage park car and start looking under it and nothing what interesting level of coolant drop to minimum like it was when I have get my car :?
so instead of leave it in garage I took it for spin, stops around 20 times and no leak visible push hard nothing coolant level same spot.
p.s. I have nice footage from gopro but after watching I can't upload to youtube wrong angle and too many numbers are visible :cop:
So this is my list of :?:
1. should warning shows up if coolant was below minimum if yes what I should check,
2. since coolant will be off I need LTT and new pump where I could/should get these from I have read about Hartech should I contact with them?
3. what coolant, in my Porsche I have some pink stuff not sure brand or what it is.
Car will be back to garage tomorrow on jacks, all splash shields off and looking for leak all pipes to check great fun :eh!:
Regards
Szymon
Regards
Szymon
