997 : 2004- 64
Cayman : 2005- 22
Macan : 2014- 7
PostPosted: Fri Apr 20, 2018 3:26 pm    Post subject: Steve Wright's Serious Moddin' - SSK solid bush/bearing Reply with quote
It's Friday, it's Sunny, Steve Wright's Serious Jockin' is on the Radio. There's only one thing for it - Serious Moddin'!
Due to 911uk peer pressure, sloppy bushes and the need to keep myself busy when work load is sparse I've started attacking the cheap eBay Short Shift Kit with the end result being solid oilite bearings and Phosphor Bronze bushes (yes that's bushes, not bushings as some of you guys like to refer them as) instead of the poor needle bearing and plastic bushes the kit comes with fitted.
So, this breaks down in to two part - Part 1, replacement of the badly spec'd needle bearing that runs on a 10mm shaft through the centre. This is the part the lever rotates on in the up/down movement, ie. 1st to 2nd, 3rd to 4th, 5th to 6th. Part 2 - replacement of the plastic bushes that the whole cradle rotates on that are fitted in the gear shifter assembly. The cradle rotates on these for the left/right movement, so moving over from 2nd to 3rd, 4th to 5th, reverse, etc.
The end result should be a full shifter assembly with no play in it created by poor manufacturing tolerances and clearances, ensuring that the lever is rock solid in the assembly and any movement from the operator transfers directly to what happens at the gearbox end and thus results in Sniper accuracy and selection for all you sharp shooters out there, hopefully transferring your driving ability from Shooter to Driving
Part 1
Replacement of the central needle bearing with self lubricating solid bearings.
See here the issue with the poor quality needle bearing. The lever is allowed to rock on the central shaft as there's too much clearance between shaft and bearing:
Open Youtube Page
This bearing is just pressed in the leaver, so easily pressed out ready for the solid bearings. I've spec'd the bearing but need to modify them slightly on my lathe so once pressed in, the overall width of the bearings in the leaver are a nice snug fit in the aperture in the cradle. The bearings are also a perfect fit on the shft so no excessive play is evident (as seen in the above clip). Here's with the solid bearings fit and as you can see, no rocking about, only perfect rotational movement.
Open Youtube Page
Seen here, nice and solid and should outlast the car's life.
The central assembly (lever and cradle) are now assembly back together ready for part 2.
Part 2
Replacement of the plastic bushes with solid bearings.
Now this is where it started to get complicated and I soon realised why the plastic bushes (which I originally thought were ok for the job) are like they are and not the perfect solution.
Here you can see the clearance between the upper and lower cradle pivot shafts and the plastic bushes. When measuring, clearance between them was up to 0.5mm Surprised when in reality 0.05mm would've been somewhere near acceptable.
Open Youtube Page
It was only at this point that I thought I better check out the upper and lower shafts in the cradle for being concentric to each other (ie. in line with each other so they rotate on the same virtual centre line). WTF? These things are a back yard out. No wonder they need so much clearance in the plastic bearings otherwise these things would just lock up.
I've made a video here in my lathe clamping on one of the shafts and then witnessing how far the other end is running out. Remember guys - CNC machined doesn't mean ACCURACY!!!!! That's all down to the person using it.
Notice the outer side face of the cradle running perfectly true, whilst the shaft is bobbing up and down like brides nightie:
Open Youtube Page
So I've had to take a skim off this and reduce the shaft down in size to ensure it's running concentric with the opposite end. See here now I've reduced the diameter and got it running how it should (it's running that true you can't tell it's spinning):
Open Youtube Page
Once that's sorted, time to take a few measurements, jump on the lathe with a Phosphor Bronze bar and machine some solid bushes (to 0.01mm accuracy for perfect movement when assembled).
And hey presto, ready for assembly.
All back together and a few snazzy snaps before fitting back in the car.
Now back in the motor and re-assembled back in the full assembly.
......and a quick dress rehearsal before jumping in and taking if for a spin. Gear stick is now rock solid and any movement between lever and Gearbox leavers is free from any play created by the original SSK. thumbsup
Open Youtube Page
Right, what am I doing dicking about on here writing this? I should be in a beer garden doing some Steve Wright's Serious Boozin'
Abientot mon Amis!!!!!!!! Drinkers
maldren
PostPosted: Fri Apr 20, 2018 4:00 pm    Post subject: Reply with quote
Looks great Alex. For me, the question is do I go for this or your 997 modification.
My gearshift is a little tight when cold but otherwise ok but I'm sure a modified shorter shift will be more precise.
Having not tried either, are you in a position to compare and contrast? Do you know how far the throws are for the two options?
thanks
Mike
Mike
PostPosted: Fri Apr 20, 2018 4:03 pm    Post subject: Reply with quote
Great thread Alex, those two vids showing the bobbing up and down like a brides nighty v how it looks after you machines it is amazing.
We have to call them bushings down here as a too many bush references would tempt the pics Floor Grin I dont actually think bushings is a real word Floor
Looking forward to when your ready to sell them mate. Thumb hopefully I am quite high on the list Grin Thumb
enjoy your beer Cheers
Chief
PostPosted: Fri Apr 20, 2018 4:12 pm    Post subject: Reply with quote
Brilliant work!
I love an engineered solution to a cost cutting exercise Thumb
- 964 C2 The Red Baron - 914 2.0 Project Blue Book - Cayman S Sport Edition Amber Alert! -
Instagram - @chiefporsche
PostPosted: Fri Apr 20, 2018 4:45 pm    Post subject: Reply with quote
Will do!
kas750
Shanghai
2006 Porsche 911
PostPosted: Fri Apr 20, 2018 4:51 pm    Post subject: Reply with quote
Top work Alex Thumb
FZP
Estoril
PostPosted: Fri Apr 20, 2018 5:11 pm    Post subject: Reply with quote
Solid work mate. Look forward to seeing it at the pub during next month's coffee catch up
PostPosted: Fri Apr 20, 2018 5:21 pm    Post subject: Reply with quote
Pub? Now that's what I'm talking about Thumb
Dammit
PostPosted: Fri Apr 20, 2018 5:23 pm    Post subject: Reply with quote
Something very pleasing about the second lathe clip.
Would your modifications to a standard 997 shifter move it too/beyond the precision of the 997.2 GT3 shifter, which everyone talks about being the benchmark?
= my understanding (which may be imperfect) is that said shifter is stock 997 but with better/solid bearings/bushings.
PostPosted: Fri Apr 20, 2018 5:31 pm    Post subject: Reply with quote
From what I've read and seen, this mod takes it beyond everything, so yes.
I was having a good browse last night and the companies who do solid stuff don't even use the right materials. But they love writing shoite like CNC machined & stealth black. Grin
ragpicker
Reims
PostPosted: Fri Apr 20, 2018 5:47 pm    Post subject: Reply with quote
Cracking stuff again dude!
It looks so precise that it would feel abnormal using it. There's usually a bit of slack in every box, if you know what I mean Embarassed
996 turbo - FOR SALE, Price reduced: http://911uk.com/viewtopic.php?t=131025&highlight=
PostPosted: Fri Apr 20, 2018 6:00 pm    Post subject: Reply with quote
Just in from the boozer. This thing is proper point and press! didn't miss a gear, even after the 4th!!!
rhino-man
PostPosted: Fri Apr 20, 2018 7:58 pm    Post subject: Reply with quote
What are you going to offer us for purchase then Alex?
Our 996 is 120k miles so gear change is past its best even with new engine and transmission mounts and fresh oil so this is the next mod on my list.
2010 997.2 C4S
2001 996 C2 Convertible
PostPosted: Fri Apr 20, 2018 8:03 pm    Post subject: Reply with quote
I'm working on it. Watch this space.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Apr 20, 2018 8:35 pm    Post subject: Reply with quote
That looks like a top job. Are you going to look at doing anything for the plastic piece which translates the left-right movement of the lever in to forwards-backwards movement on the cable? This always appears to have plenty of slop in it.
PostPosted: Fri Apr 20, 2018 8:45 pm    Post subject: Reply with quote
Will look in to it. As yet any current solutions I've seen don't look too clever. I'll come up with a really cheap natural solution that pisses on their parade.
kurlykris
PostPosted: Fri Apr 20, 2018 9:19 pm    Post subject: Reply with quote
Nice work Alex Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
Cybot7
2001 Porsche 996 Carrera 2
PostPosted: Sat Apr 21, 2018 6:49 am    Post subject: Reply with quote
I’m impressed. Great bit of engineering.
Nothing is foolproof to a sufficiently talented fool
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sat Apr 21, 2018 7:56 am    Post subject: Reply with quote
Nice work! There is a guy on boxa.net doing something similar:
http://www.boxa.net/forum/topic/68109-quick-shift-kits/?page=4
PostPosted: Sat Apr 21, 2018 7:58 am    Post subject: Reply with quote
You do not have permission to view this content.
Goto page 1, 2, 3, 4, 5, 6  Next
Page 1 of 6
