Porsche 911UK Forum
pasm not working
gilly358
Member
15 Apr 2018
7
hi guys has anybody had a problem after a power out on the with the pasm
not working, we had a problem with the battery lead loose in the terminal and with power now back on the pasm isn't working at all does anybody have any ideas ?? :?: when you press the button there is no light on the switch when pressed
You need a tester on it and a check for fault codes really ..
Battery faults would indicate a steering angle sensor calibration is required .. but that wont normally give a pasm fault , it would give a PSM fault .
i would also check ALL the fuses just in case .
Garage ?
thanks for the reply looks like its a trip to the Porsche specialist :thumbs:
124,354
1,439,455
48,710
Silage
