997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 14
Cayenne : 2003- 3
gilly358
PostPosted: Mon Apr 16, 2018 7:20 pm    Post subject: pasm not working Reply with quote
hi guys has anybody had a problem after a power out on the with the pasm
not working, we had a problem with the battery lead loose in the terminal and with power now back on the pasm isn't working at all does anybody have any ideas ?? Question when you press the button there is no light on the switch when pressed
PostPosted: Mon Apr 16, 2018 7:40 pm    Post subject: Reply with quote
You need a tester on it and a check for fault codes really ..
Battery faults would indicate a steering angle sensor calibration is required .. but that wont normally give a pasm fault , it would give a PSM fault .
i would also check ALL the fuses just in case .
Garage ?
gilly358
PostPosted: Mon Apr 16, 2018 7:49 pm    Post subject: Reply with quote
thanks for the reply looks like its a trip to the Porsche specialist thumbsup
