997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
PostPosted: Sat Apr 14, 2018 6:49 pm    Post subject: Seat belt height adjuster strip and rebuild Reply with quote
Link here ..
https://youtu.be/EwakFlGvgMs
Audio didnt work .. sorry .
The tabs at the beginning are what you need to bend out to remove it .. this is not listed in the Porsche instructions , a small flat bladed screwdriver and you try and lever out each side whilst pulling on the adjuster .. you finish with levering the base at that pin .
Next part is the 6 locking tabs .
The metal plate is often loose and causes a rattle .. bend the fingers a bit to give then a tighter fit.
if it rattles then perhaps something like spray grease on the adjuster that moves up and down and the contact points of the various parts .
Couple of images below .
Ive posted this in the 996 and 997 forums as this applys to both cars .
 Filesize:  196.85 KB
 Viewed:  666 Time(s)
 Filesize:  253.79 KB
 Viewed:  666 Time(s)
 Filesize:  135.64 KB
 Viewed:  679 Time(s)
Fingers that can be adjusted but they MUST sit on top of the metal bracket .
 Filesize:  134.24 KB
 Viewed:  679 Time(s)
EGTE
PostPosted: Sun Apr 15, 2018 2:35 pm    Post subject: Reply with quote
Thanks for this Thumb
Both of mine are in bits right now, due to excessive rattling/creaking from the plastic covers. Can rebuild them now.
