997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
PostPosted: Sat Apr 14, 2018 6:29 pm    Post subject: Seat belt height adjuster strip and rebuild Reply with quote
Link here ..
https://youtu.be/EwakFlGvgMs
Audio didnt work .. sorry .
The tabs at the beginning are what you need to bend out to remove it .. this is not listed in the Porsche instructions , a small flat bladed screwdriver and you try and lever out each side whilst pulling on the adjuster .. you finish with levering the base at that pin .
Next part is the 6 locking tabs .
The metal plate is often loose and causes a rattle .. bend the fingers a bit to give then a tighter fit.
if it rattles then perhaps something like spray grease on the adjuster that moves up and down and the contact points of the various parts .
Couple of images below .
 Filesize:  196.85 KB
 Viewed:  1002 Time(s)
 Filesize:  253.79 KB
 Filesize:  135.64 KB
 Viewed:  1025 Time(s)
Fingers that can be adjusted but they MUST sit on top of the metal bracket .
 Filesize:  134.24 KB
ragpicker
Estoril
PostPosted: Sat Apr 14, 2018 8:23 pm    Post subject: Reply with quote
What a shame the audio didn't work!
It's like poetry in motion watching that rather funky screwdriver being expertly wafted around.
Splendid stuff!
PostPosted: Sun Apr 15, 2018 5:35 pm    Post subject: Reply with quote
Tell me about it .. i had to get my Daughter to film it on an old work camera i use .. 2.41 mins of her life was a bit too long to help out i feel so i had no chance of trying to figure out the sound fault !
My first attempt at a video .. ok .. well .. ish no sound and not a brilliant quality but it will do the job along with the pictures.
deft hands Floor .. old beat up ones more like Thumb
Jam911
PostPosted: Sun Apr 15, 2018 6:52 pm    Post subject: Reply with quote
https://rennlist.com/forums/996-forum/799545-how-do-i-reinstall-the-plastic-seat-belt-adjuster-in-my-2004-a.html
Read this too
Current '07 997 C4S
Ex '99 2.5 Boxster
