996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
tedzwedz
Location: Ladbroke Grove, London & North Yorkshire, & Isle of Carna - Scotland
1998 Porsche 996 Carrera 2
PostPosted: Sat Apr 14, 2018 2:52 pm    Post subject: Drip under very heavy rain - roof of C2 coupe onto rear seat Reply with quote
Hi All
As above when we had that torrential rain a week or so ago after easter I noticed my rear seat was a bit damp, looked up and there was a drip from the roof corner at the back.
Any ideas?
Best Edward
1998 C2 Coupe
1998 Porsche 911 (996) C2 - GT3 SplitRim 18" Alloys, Oettle Porsche Sports Exhaust, K&N Airfilter, Silicone Cold Air Intake, Quad Exhaust Tips, Litronic Headlights (2008 - )
2012 Piaggio Vespa LX 125ie (way faster than the 911 around London!)
thecarfixer
PostPosted: Sat Apr 14, 2018 5:13 pm    Post subject: Reply with quote
Sunroof or non?
tedzwedz
PostPosted: Sat Apr 14, 2018 6:51 pm    Post subject: Reply with quote
thecarfixer wrote:
Sunroof or non?
cheers, sunroof!
alex yates
PostPosted: Sat Apr 14, 2018 6:53 pm    Post subject: Reply with quote
There's your answer.
tedzwedz
PostPosted: Sat Apr 14, 2018 7:03 pm    Post subject: Reply with quote
but why would it leak in the corner near the roof channel drains?
Would it not leak around the sunroof
PostPosted: Sat Apr 14, 2018 7:16 pm    Post subject: Reply with quote
Might help ..
https://rennlist.com/forums/996-forum/876781-sunroof-drain-found-leak-how-to-fix.html
Open the roof , pour some water into the channels and see if it leaks .. rear drain tube blocked is a probable answer .
no.15 is the rear drain tubes.
 Filesize:  33.97 KB
 Viewed:  1504 Time(s)
willy
PostPosted: Mon Apr 16, 2018 7:57 am    Post subject: Reply with quote
Hi Edward
Have been fixing the same problem only this week in mine. I had a wet rear seat and a wet rear floor.
As per the earlier responses, your sunroof has a drainage channel at each corner.
The sunroof is designed to pass excess water through the roof and down these channels into plastic pipes which lead to outlets around the wheel areas.
In your case (like mine) there is a a pipe running from the corner of the rear of the sunroof, down roof (above the rear quarterlight window) and it ends at an outlet just above the rear wheel where it drains to.
To resolve is not hard but its pretty time consuming (and no doubt others will have more cunning methods to fix).
I took off the rear seat base, the parcel shelf and the rear side trim. There is lots of foam here that may be soaking so remove it and dry it out. Lift up as much carpet as you can and squeeze. Its amazing how much water there can be,
To fix the problem, pull the roof liner from its clips to reveal the outlet of the sunroof and where it attaches to the pipe. At other end, under all that foam in the far rear corner of the car you will see the outlet of the pipe with a 90 degree plug on it.
There can be a blockage anywhere through this route i.e. at the sunroof connection, the pipe or at the exit point from the car.
I removed the pipe and rodded it gently with some earth wire (making sure there were no exposed wire ends that could poke a hole). My pipe was clear.
I also rodded the sunroof corner in case it was there - again clear.
My problem was not blockage - it was that (a) the male spigot type connector on the sunroof had a hairline crack and was leaking and (b) the plastic tube was leaking on this also. Simply put - a leak from the top corner of the sunroof.
There is no spare part for this to my knowledge unless you wish to buy a new sunroof chassis, so glue and silicon it is.
I ran some glue along the cracked connector. Siliconed over once dry. Heated the plastic tube and reattached with silicon and cable ties. Perfect!
I also ran some vaseline around the sunroof seal from outside the car. I think this is an `old boys trick` but my workshop guys said its worth doing.
Fortunately, I'm a small chap and found working in the back of the car ok.
Good luck if you're of a bigger frame. You may want to consider removing the front seat.
1998 996 Carrera Ocean Blue
PostPosted: Mon Apr 16, 2018 7:52 pm    Post subject: Reply with quote
@ willy
Credit where its due young man .. excellent post .. worship
willy
PostPosted: Tue Apr 17, 2018 5:26 pm    Post subject: Reply with quote
deMort wrote:
@ willy
Embarassed
I'm not worthy of such praise from you Oh Master Of The Porsche!!!! But thanks all the same Smile
Edward
Another sneaky little area for a leak to get in around that area is where the rearmost retaining bolt of the quarter light window works loose. This results in the quarter light window seal letting water through.
Again, if you have removed the interior trim you will see this. Its a small allen headed bolt through a 1" washer with a foam backing.
tedzwedz
PostPosted: Wed Apr 18, 2018 1:21 pm    Post subject: Reply with quote
Thank you very much all, very helpful!!!!
Best Edward
