996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
PostPosted: Sun Dec 30, 2018 5:34 pm    Post subject: Reply with quote
Ive had something similar on a Boxster recently .. this was a battery discharge .. no computer illumination but it was on Fuse B1.
I found that unplugging the cluster stopped the battery discharge so logically i thought it was the cluster ..
However i was concerned something might be keeping the cluster awake .
I was unable to get to an end fix though as the customer is keeping it on a trickle charger rather than possibly paying out for a very expensive instrument cluster .
I dont know if there are places that can test things like a cluster but i feel that might be a way forward .
Fault code check is another .. if you have a code in the cluster saying its faulty ... then it probably is .
EDIT ..
I think i would start by unplugging the computer stalk .. just to see if that stops it .. a stuck switch perhaps.
Fuse B1 is the main power supply to the cluster .
 Filesize:  164.03 KB
 Viewed:  313 Time(s)
 Filesize:  481.62 KB
 Viewed:  313 Time(s)
Goto page Previous  1, 2
Page 2 of 2
