964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
Thomp1983
PostPosted: Thu Apr 12, 2018 4:54 pm    Post subject: Another issue, it keeps beeping at me Reply with quote
Well it seems I'm on a roll with the car having issues at the minute. Ever since I reconnected the battery whilst it was off the road for welding the car has started beeping at me.
It beeps once when I get out of the car and then beeps twice when it's locked, I believe this is to signify an issue with the alarm/ locking system. I thought it'd be easy to check using durametric but I keep getting an error saying the cable can't be detected.
I'm wondering if the issue is the ignition switch although I replaced it last year with a new one as it wasn't returning from the start position.
Without durametric is there an easy way of testing what's causing the beeping?
Chris
alex yates
PostPosted: Thu Apr 12, 2018 5:09 pm    Post subject: Reply with quote
Make sure everything in the car is shut including door pockets and glove box.
ragpicker
Estoril
PostPosted: Thu Apr 12, 2018 5:14 pm    Post subject: Reply with quote
Centre console cubby hole lid, thats the usual place for me. When I lean on it my elbow slightly pushes the button and releases the lid. I don't realise until I lock it and it starts complaining
alex yates
PostPosted: Thu Apr 12, 2018 5:15 pm    Post subject: Reply with quote
Snap.
Fastlane
PostPosted: Thu Apr 12, 2018 7:44 pm    Post subject: Reply with quote
Snap + 1
Currently Porsche-less, Ariel Atom 3 310
Past:
2001 Zanzibar Red 996.1 C4
1992 Zermatt Silver 964 turbo
1991 Midnight Blue 964 turbo
1994 Guards Red 968 Sport
1987 Baltic Blue 928 S4 auto
PostPosted: Thu Apr 12, 2018 7:51 pm    Post subject: Reply with quote
Im going to be different just for the hell of it .. also i dont think its the center consol lid Razz
Beep once .. something is not in a position that the alarm system likes .. it see something open basically ..
Beep twice and its a fault .. something is not doing what it should and not something thats open ..
Im going with a door lock ass. and probably the drivers side as thats the most common of the 2 to fail
You need a tester to check as its a 5 min job to diagnose .
The cable fault .. yup its a pain .. it seems when ever i use ours it does that .. i unplug and plug the lead back in then run the software again .. sometimes several times .. also try staying in the program and unplug/plug it then try accessing the system .
After that i use the Piwis or autologic tester as ive lost patience .
Thomp1983
PostPosted: Thu Apr 12, 2018 8:14 pm    Post subject: Reply with quote
Now you mention locks demort, awhile ago I unlocked the car and the passenger door didn't open I had to cycle the locking a few times to get it to open could it be linked?
The beeping didn't start until quite awhile after that though.
Is there a way to test the locks without a tester incase my cable continues to refuse to play ball?
PostPosted: Thu Apr 12, 2018 9:47 pm    Post subject: Reply with quote
Glove box sensor on mine nooo
JS1500
PostPosted: Fri Apr 13, 2018 5:30 pm    Post subject: Reply with quote
I reckon passenger side door lock actuator. Question
2000 996 C4 - Guards Red
PostPosted: Fri Apr 13, 2018 6:45 pm    Post subject: Reply with quote
Yup it could well be the passenger lock .. but we are all guessing and there are several items that could cause this fault .
Its a quick job to diagnose with a tester .. you look at the values for all the items involved then lock the car .. the doors have a normal lock and a secured lock so it might say secured but not locked .. it may well be seeing a key barrel stuck on open .
you cant check a lock as such without a lot of work and a wiring diagram .. you would have to test each micro switch .. and then possibly the same for the other side ..
Its not worth the effort .
I had a chat at work about the cable fault .. boss says its normally the usb port on the computer , try another usb port and perhaps have a look at the cable usb .. contacts all ok etc .
You could also try reinstaling the software .
Need to get a tester on it basically .
@ JS1500 no arguments from me there Thumb
Thomp1983
PostPosted: Mon Jul 09, 2018 4:52 pm    Post subject: Reply with quote
Time to bump an old thread, I've now got a working durametric pro cable so how would I go about testing what's causing the issue?
I can say it's not the cubby hole latch I tested it with a multimeter and it's working properly, I'm going to remove the bonnet and engine bay switches next and check them with the meter as there easy access
PostPosted: Mon Jul 09, 2018 5:37 pm    Post subject: Reply with quote
There should be some actual values for the alarm system .. your looking for something that says front bonnet , door open , door secure etc etc
You then check the value against the item .. so does it say door closed on the tester when the door is closed .. does it say both doors are secured when you lock the car and so on .
David Ramsbotham
PostPosted: Tue Jul 10, 2018 3:19 pm    Post subject: Reply with quote
Just to add my recent experience - 2 beeps after locking turned out to interior monitoring sensor had given up. Local Porsche centre wanted to charge me £188 for sensor plus minimum of 2 hours labour ( “ don’t really know how long it will take we have never done one before!”) for grand total of at least £392.
Purchased good second hand complete interior light unit ( where monitor is housed) for £45 and fitted in 10 minutes - result!
Thomp1983
PostPosted: Tue Jul 10, 2018 4:47 pm    Post subject: Reply with quote
Demort I don't know if your work has a different version of durametric to me(v6.5.5.5) but I can't see an option for actual values in the alarm section?
the activations section allows me to lock and secure the doors and the other latches etc. but there's nothing I can see that shows what's activated/locked when I press the fob?
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue Jul 10, 2018 4:56 pm    Post subject: Reply with quote
Nothing under Alarm > fault codes perhaps?
On the 9x7 there is an led flash sequence which shows where the issue is, once alarm has triggered.
Thomp1983
PostPosted: Tue Jul 10, 2018 5:16 pm    Post subject: Reply with quote
Unfortunately not Jonno it just shows no faults found
PostPosted: Tue Jul 10, 2018 6:22 pm    Post subject: Reply with quote
Im afraid that whilst we do have Durametric its not something i really use very often , Autologic and piwis are my main testers of choice.
I find it strange it doesnt have the values though but if you have the latest version then i guess not , im sure i have seen it though so im a little confused .. gen 2 only Dont know
In this case i think a local indy useing their tester would be the cheapest and quickest way of diagnoseing your fault.
Guywilko
PostPosted: Wed Jul 11, 2018 4:25 pm    Post subject: Reply with quote
Any idea which side this is?? Passenger or drive
Guywilko
PostPosted: Wed Jul 11, 2018 4:27 pm    Post subject: Reply with quote
Soz !
couldnt post pic.
codes are 46 60 47 61 59 33 3
cheers
Thomp1983
PostPosted: Thu Jul 12, 2018 6:55 pm    Post subject: Reply with quote
Guywilko wrote:
Soz !
couldnt post pic.
cheers
Sorry I don't know, maybe starting a new thread with a description of your issues may help
