CAT6 Tracker - Any Recommendations?
AdeD
Sao Paulo
10 Oct 2010
881
So while i don't really want one i'm told i need a CAT 6 Tracker. I don't want to use the built in Porsche one and I've lost the fobs and it's unlikely to still work anyway so looking for any other recommendations...
Vodafone can supply new fobs so there's no problem there.
One alternative is MetaTrak which has the added bonus of allowing you to track the position of your car via GPS and record journey data - though that might also be viewed as a negative :cop: - and like Vodafone requires a separate fob...
Just had a similar issue and ended up re booting the Porsche VTS. As much as its a pain in the rse twas cheapest easiest option.
This! Just had to do the same - new fob £30 very easy and simple to set up! £ 217 subscription per year! Very easy and painless!
Who do you use for Insurance? When looking for mine it was tricky finding companies that would cover an ES without charging a fortune. I ended up with Classicline (limited mileage, garage etc but no tracker required) but be good to know any other recommendations for renewal. PM if you want :thumb:
PM sent
Classic line told me the same thing. I was sceptical and asked them to double check which they did and turns out they were wrong and i did actually need a tracker..just FYI.
Good to know. I will quiz them further come renewal in a couple of weeks.
I did not need a tracker with my BGTS or 993 with Classicline.
I double checked with them as I had an active tracker on the boxster which I let lapse this month due to it not being needed.
124,563
1,441,544
48,979
Lb456
