964 : 1989-1993 6
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
sim996
PostPosted: Thu Apr 12, 2018 8:57 pm    Post subject: Reply with quote
FRP wrote:
So it for a 996 big HP build, ahhhhhh this i know well !!!
You dont need a GT2 box end of
Bill Raider build, GT2 slave the usual stronger bits and chose your ratios
You will need to disconnect your front diff
Depending on boost levels and agression, you will need to change drive shafts
And some other bits
So what are the usual stronger bits?
Would it be per chance a 997 GT2 input shaft and 1-3 gears, LSD and spray bar...
I believe it's RADER for the bloke over the pond
Stuart Mackay
PostPosted: Thu Apr 12, 2018 11:49 pm    Post subject: Reply with quote
Have you spoken to Matt at Fearnsport or the lads at ES Motor, they would be my first ports of call for someone who might know of such a piece of hardware lying under a bench?
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
FRP
PostPosted: Fri Apr 13, 2018 4:23 am    Post subject: Reply with quote
Speak to Ken or Adam at 9e
I have a gearbox from them for my car. 1000 bhp etc. No complaints what so ever .... it runs perfect and 100% drivability
Yes over the pond!
Yes stronger shafts. Straight cut gears for 3 4 5 etc (no 100% hard launches as you will break stuff.....you don’t need t with this kind nd of power level). Custom clutch. Guards LSD etc. But as for the finer details you will have to call them — 9e
For 1000 bhp you will need the LSD end of.
2002 996tt x50 manual in bassat black - 9eXX
sim996
PostPosted: Fri Apr 13, 2018 5:58 am    Post subject: Reply with quote
I'm not keen on straight cut, I've got straight cut in my Westfield and I don't mind the noise in that because of what it is. The Porsche is a road car.
FRP
PostPosted: Fri Apr 13, 2018 6:18 am    Post subject: Reply with quote
1000 bhp and the way it will lay down or the determined boost levels on the way the power is delivered may determine the gearbox requirements implemented ?
It depends on your route, but there aint no cheap method - ask me how i know LOL !
I have straight cut in 3, 4 and 5th gears with associated boost by RPM, after all i want to keep traction at its optimal level....well i try to LOL
BTW - I love the noise - each to their own! a real sense of occasion and that is what i want from my car along with its other mods. Its (the whine) not that bad with all the interior insulation TBH. I dont have any other toys except my wifes 0.9l Renault Clio, oh but its so easy to drive?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Apr 13, 2018 6:19 am    Post subject: Reply with quote
If you don't want straight cut then I suggest you set up the car to keep the torque down. From my research if you are going to put a lot of torque through the 'box you will need straight cut gears to reduce the side loads. Guard appear to be pretty much the only game in town when it comes to great gear sets.
There are a few specialists who will be able to advise on this, most have been mentioned in this thread. I wouldn't risk not going straight cut myself. I would hate to spend many thousands on the work, go against the recommendations of the engine builder, then have a gearbox failure. It is simply not worth the risk. Stick to 700hp or below and the standard gearbox should be fine.
FRP
PostPosted: Fri Apr 13, 2018 6:33 am    Post subject: Reply with quote
Wise words from MC
Std healthy gearbox will run circa 700bhp all day long
sim996
PostPosted: Fri Apr 13, 2018 4:30 pm    Post subject: Reply with quote
I've got the syvecs, so I can limit torque no problem, was looking at around 800ft/lbs and let it run out, probably see 900+ hp, turbos are new A3076.
Engine is 4.0, so will have plenty of torque.
Looking at options, if I have to go straight cut I might, but I don't think the 997 GT2 is straight cut, and I'm told that will handle my power level.
Yes, I think the guards is a must, but I'm thinking ATB instead of clutch packs, as I want this to be a nice drive as opposed to all out power. It won't be tracked, but if I put my foot in I don't want to worry, so I want that reliability, hence building in a bit of headroom.
ragpicker
Estoril
PostPosted: Fri Apr 13, 2018 5:26 pm    Post subject: Reply with quote
Sounds like a great build!
What's the lag like on those blowers, and what kind of boost are you looking to run?
sim996
PostPosted: Fri Apr 13, 2018 5:37 pm    Post subject: Reply with quote
On a 4.0 they should be pretty well matched, I dont want lag for a road car, they must be driveable from low down. I like usable torque. They're the xona wheel ones so hopefully plenty of spool.
Not sure on boost, will see when we map.
FRP
PostPosted: Fri Apr 13, 2018 6:27 pm    Post subject: Reply with quote
SOUNDS COOL, keep the info coming, sounds mega
Mine is only a 3.8 tho and running custom Tial Sport Xona 1180 Turbochargers
Standard at approx 1.2/1.3 boost. Can run 1.5 boost all day long and crank it up to 1.8+ when needed but is very hairy on boost at the higher end. Car is boosted to RPM to ensure traction loss is as minimal as possible and have various maps on the controller
Lag is there dont get me wrong, just gotta keep it in the correct rev range and you are ready to go,,,,,literly !
Do live / real mapping, absolulty no point in getting it on a rolling road IMHO....just saying
Where are you based ?
PostPosted: Fri Apr 13, 2018 6:37 pm    Post subject: Reply with quote
Yeah
worship
Norfolk & Idea
PostPosted: Sat Apr 14, 2018 7:15 am    Post subject: Reply with quote
FRP wrote:
Wise words from MC
Yeah, wise words indeed. Certainly makes sense to me. What are the bhp upper limits with a PDK?
2012 997.2 Turbo Basalt Black. Bit of a 9E ing.
2008 Ducati 1098R (Track)
2016 Macan GTS
2008 Vito Sport- Household Star!
2018 Ducati Panigale V4S (Track)
isysman
PostPosted: Sat Apr 14, 2018 11:45 am    Post subject: Reply with quote
sim996 wrote:
8 replies, not 1 gearbox offered. Blimmin Eck.
I think I have one in my others trousers...
911 GT2RS Build & 981 Boxster S
Sold ~ 987 Boxster S 3.4, 997.1 3.8 Cab, 987 3.2 Boxster S, 986 Boxster 2.5
Jay Are
PostPosted: Mon Apr 16, 2018 9:06 pm    Post subject: Reply with quote
Not sure what it is (996/997) but there was definitely a GT2 Box in Liverpool for ages. Tech 9 perhaps...
came out of a race car so God knows what state it was in. I looked at it but decided £15k was a bit rich for my needs especially as it was of unknown quality - that said, they were offering to strip / rebuild as proof of useability as I recall... worth asking.
They may still have it. I have a feeling it's a 996 box but there won't be much difference - will there?? Question
987 turbo S
116618LN
PostPosted: Mon Apr 16, 2018 9:53 pm    Post subject: Reply with quote
Someones selling a box on 6speed with a load of goodies. Might be what you're looking for...
https://www.6speedonline.com/forums/automotive-parts-accessories-sale-wanted/416722-fs-996tt-gt2-gearbox-w-cooler-guard-gt2-pro-lsd.html
09 997tt - Build in progress
79 911 targa
sim996
PostPosted: Wed Apr 18, 2018 11:28 am    Post subject: Reply with quote
Aye, I've spoke to him. Trying to get some prices on a 997 GT2 input shaft and gears, that's the difference over the 996 GT2 box, it's much stronger in the 997 and a proven upgrade.
My other issue is, do far almost everything I have ever bought from the yanks has turned out to be garbage.
sim996
My other issue is, it's in America.
sim996
PostPosted: Thu Apr 19, 2018 5:42 am    Post subject: Reply with quote
Thanks for the lead. I just emailed him and they had one but sold it.
FRP
PostPosted: Thu Apr 19, 2018 6:09 am    Post subject: Reply with quote
BUILDING YOUR OWN GEARBOX (I did not tho as way beyone me) if its any help, this is a good list of what you might require or at least the modified bits, its a starter for 10 anyways
big shaft nut - input
big shaft nut - pinion
small shaft nut - input
small shaft nut - pinion
Guards billet LSD if a manual gearbox
CMS billet diff side cover
CMS billet bearing clamping plate
GT3 shift leaver
1st gear syncro set
2nd gear syncro set racing steel version
steel syncros 3rd thru 6th
CMS 3/4 shift set
GT2RS main shaft 1st and 2nd gear
Decide on straight cut gears 3rd, 4th 5th and 6th ???
modified oil pick up and return fittings plus misc other small items
Page 2 of 3
