996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
Pickse
PostPosted: Mon Apr 09, 2018 5:54 pm    Post subject: 996T Age takes it's toll Reply with quote
Some may recall the trouble I had last year with corroded Tiptronic pipes causing me to breakdown in Belgium.
I wanted to avoid the experience of an unreliable car this year and so booked the car in to give it a good check over. Expecting to drop the engine and fix a couple of brake lines and weld those pesky bonded pipe joints in an effort to enhance reliability.
Below is a summary of things found. It makes pretty scary reading for a car I thought was in generally good nick.
Bank 2 turbo charger has a hole in the centre housing, and Bank 1 heavily corroded. Also the manifold to turbo fixings and turbo heatshields are heavily corroded – See attached pictures
Nearside front outer CV Boot split. The 3 others are perished
Brake pipes from front splitter block including one across front axle heavily corroded
Underbody rear brake pipes heavily corroded
Coolant leak from underbody hoses
Gearbox end gaskets, and sump leaking ATF
Front damper bodies heavily corroded and play in offside when wheel on full droop
Both rear toe control arms have play in the ball joints
Front lower control arm bushes separating from arms
A wheel alignment would be required after the above three items
Slight oil leaks from around the chain housings, and chain guide pin washers
Scavenger pump lower unions heavily corroded
Fuel cap seal perished
Offside reverse light not working
Offside front wheel arch liner missing some fixings and insecure
Right hand spoiler ram leaking oil
Pickse
2003 Arctic Silver 996 Turbo Tiptronic S
ragpicker
Estoril
PostPosted: Mon Apr 09, 2018 6:05 pm    Post subject: Reply with quote
I'm sure its no consolation but I've replaced every item on your list (plus many, many more) during the ownership of my turbo.
Not cheap cars to run, but what 15-20 year old supercar is?
Luckily I do a bit myself but things like the engine rebuild I had done, that was done by someone who knows what they're doing Thumb
Fastlane
PostPosted: Mon Apr 09, 2018 7:08 pm    Post subject: Reply with quote
That is quite a list, but as has been said an old supercar is still a supercar, with supercar running costs.
I imagine you can work your way through some of those fixing/sourcing parts yourself? Has the garage provided a breakdown of cost to rectify each area?
Good luck!
Currently Porsche-less, Ariel Atom 3 310
Past:
2001 Zanzibar Red 996.1 C4
1992 Zermatt Silver 964 turbo
1991 Midnight Blue 964 turbo
1994 Guards Red 968 Sport
1987 Baltic Blue 928 S4 auto
Pickse
PostPosted: Mon Apr 09, 2018 7:32 pm    Post subject: Reply with quote
Thanks Andrew, some consolation.
To be fair in four years all I have 'had' to do is the water pump and the Tip pipes. Other than that just servicing.
You're right Fastlane some maintenance is only to be expected on a car of this age and complexity. But I was surprised the Turbo was rotted to the extent of having a hole in it!
Some of it will wait. Apparently the control arms & dampers are good for a while yet and I can manage to replace the filler cap and rev lamp bulb myself.
The garage did provide a price for each job. I'm just waiting on an aggregate price to do what I think are the important things now.
So two turbos, brake pipes, tip case leak and engine drop to access bonded hoses for welding and a replacement header tank.
Hopefully that will get me to Spa and back in May without AA assistance.
Still a brilliant car tho, and I'm still lovin' it Cloud 9
Pickse
kas750
Reims
2006 Porsche 911
PostPosted: Mon Apr 09, 2018 7:34 pm    Post subject: Reply with quote
Pretty standard fare on a car of that age so you shouldn't feel hard done to. Thumb
New997buyer
Yas Marina
PostPosted: Mon Apr 09, 2018 8:59 pm    Post subject: Reply with quote
Not a great list and will eat somewhat into any increase in value in the last couple of years. But on the upside the fundamental parts are okay. And what a machine it’ll be once you’ve had that work done Thumb
Surely a sign too you need to drive it more? Grin
“Forum signatures with quotes from famous people is a form of pretentiousness beyond compare, Sir!” Abraham Lincoln in conversation with Groucho Marx.
997.1 turbo man
Ex 997.1 turbo tip S, 996.2 turbo tip S, 996.1 C2 man
PostPosted: Mon Apr 09, 2018 9:55 pm    Post subject: Reply with quote
Ouch Steve. Surprised
Hopefully you'll be able to spread the pain over time and enjoy using the car in the best months of the year.
When it's all done you'll be Very Happy for another few years.
Enjoy Spa thumbsup
cheshire911
Estoril
PostPosted: Mon Apr 09, 2018 10:40 pm    Post subject: Reply with quote
The turbo ain't a budget car. I've always been quick to highlight that fact.
And as they are getting on in age, they come to need attention and money spending.
What I'm wondering is why such items were not highlighted at each annual service?
I've put mine through a annual service at OPC Chester during my ownership and they go through it with a fine tooth comb and highlight anything that it needs doing. I then tell them to put anything right. I also use my local Indy to take some labour and inspect the car to highlight anything he thinks it needs doing and put it right.
Hopefully, I avoid a big list like the one shown and the costs on an ongoing basis are manageable instead of a service with £3k of advisory extras.
But of course some might see that as OPC or indy finding extra work.
996 2002 X50 Turbo Manual
snb993
PostPosted: Tue Apr 10, 2018 9:39 am    Post subject: Reply with quote
As above - mine has had all of those replaced in my 14 years of ownership so pretty standard i think as well
Gives a great opportunity to update/upgrade without resorting to too much man-maths! Grin
996T - Cobalt blue, K24's, GT2 I/C's, Techart SSK, Manthey KWv3, H&R ARB's, RS engine mounts, Europipe, GT3RS 6 pots, 997T discs/RS29's all round etc
964 C4 - GP white, 993 C4 gearbox/front diff, Wayne remap, Bilstein B6's / H&R springs, polybushed, Cup 1's, RS SSK, gutted cat etc
993C4 - sold
928S4 - sold
Osh
PostPosted: Tue Apr 10, 2018 9:51 am    Post subject: Reply with quote
Hi Pickse - did a lot of that list in my first year; ouch indeed.
As others have said - once done, what a great car it will be and it will be another 10-15 years before needing doing again.. Thumb
Osh
gilessav
PostPosted: Tue Apr 10, 2018 10:02 am    Post subject: Reply with quote
Ouch but atleast you know what now needs doing and when.
Having just had the brake lines effectively all replaced on the C4S I can testify that is not a trivial piece of work, the ones running across the front of the car in particular......bits are cheap, labour is not so hopefully you can negotiate a discount if they are pricing all the needed jobs now!
Previously LHD 964
Currently 2004 C4S
Marky911
PostPosted: Tue Apr 10, 2018 7:47 pm    Post subject: Reply with quote
Ouch. As said, never nice news but that's what these cars cost to run.
Every hobby costs money I suppose.
I do always have to smirk when someone (I don't mean you here Pickse) pipes up about owning a 996 for a few years and it has needed nothing but servicing.
All that means is that they either A) haven't used it at all or B) Haven't had a good look around their car.
My 996 is 20 years old this year. I costs a lot. People who don't spend gradually, either end up with a big bill one day or they pass it on to the next owner.
Again as said you can source parts etc and do some of the easier jobs yourself. If you can't diy then unfortunately these cars cost a fortune to keep nice.
I shudder to think how much I'd have in mine if I gave every job to a specialist, bodyshop, interior guy etc.
markturner1960
2003 Porsche 996 GT3 Mk2
PostPosted: Tue Apr 10, 2018 8:54 pm    Post subject: Reply with quote
Oh dear, that's a long list....this is why I keep the underside of my car spotless and if it does get dirty, clean it straight away. I have had some mild stick about it, usual stuff about cars being for driving, not cleaning etc, but it still never fails to amaze me that people spend ages cleaning the paintwork and polishing it, yet it never occurs to them to do the same to the underside. Most of what you list would have been apparent long ago, or maybe avoided, if the underside was cleaned and protected regularly. I know it's not easy if you don't have access to a ramp etc, but you should try and make an underbody clean and lube a regular thing to keep these things at bay...
996 Mk2 GT3 Speed yellow
Pickse
PostPosted: Tue Apr 10, 2018 9:06 pm    Post subject: Reply with quote
Thanks for the thoughts guys.
And don't worry Kas, I'm not feeling hard done by. Didn't mean for it to come across that way.
To be fair given what I could see, even with the undertrays in place, I was concerned by the apparent level of corrosion visible, hence the inspection. So I'm not entirely surprised but as Chesire911 notes, I would have expected some comments from the annual services (Gearbox case leak excepted as this was noted).
As you say Paul, any apparent market value gain over the last few years is eroded but it's only a profit when you realise it, right? And I don't see me selling for some time yet!
Man Maths I can do, thanks snb993 but for the moment I'm going to put it all back as standard to make a reliable and enjoyable car. Can't deny I was hoping the turbos would last till an upgrade was possible but the timings not right.
In hindsight it seems I may have just got away with it for a few years or was unaware, unlike Osh, of what needed doing. Guess I took the lack of reports from service as a bill of good health.
But it will be a better car for the money spent and despite the cost, which is considerable as it's coming in one lump, I think it's an investment. I would not be happy with an unreliable car. Nor one I knew was not as good as it could be.
Anyway all done in a couple of weeks, then to Spa. Cheers Terry, thumbsup
Pickse
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Apr 10, 2018 10:08 pm    Post subject: Reply with quote
Sort of a long list, looks like a 'worst case scenario' from a gimlet-eyed mechanic who's been asked to report on anything amiss. Some of the items are easy wins, like CV boot, fuel filler seal, light, wheelarch fasteners missing.
I bet the whole lot will cost less to sort than a routine cambelt service for an F355 that's gone nowhere.
cheshire911
Estoril
PostPosted: Wed Apr 11, 2018 5:37 am    Post subject: Reply with quote
Cost less than £1200 for all that?
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Apr 11, 2018 7:26 am    Post subject: Reply with quote
Its exactly the same for ANY 15+ year old car. I don't know why people are so surprised that Porsche is any different.
Theres a reason why you don't see very many cars on the road that are over 15 years, its because the labour to fix them is more than they are worth.
People go misty eyed over their Porsche and shell out for it (me included). Of course it helps that its worth more than £1k.
Paul_911
PostPosted: Thu Apr 12, 2018 11:14 am    Post subject: Reply with quote
The way we treat are Turbo is that we roughly take on one 'big job' each year alongside its annual service. A couple of years ago we overhauled the brake pipes followed by the suspension and then last year we had the Turbos refurbished along with all the exhaust brackets etc which shed a couple of grand very easy but it was worth doing - I was always very conscious of being faced with a list like the above - all you can do is work through it. The good thing about these car rising in value is that we all free a little more comfortable about investing in them - it's easier to spend £2K on a £35-40K car than a £25K one if that makes sense - it was the man maths I used anyway.
As others have said there is most definitely a premium to the up keep of a Turbo over and above a normally aspirated car.
Ex: 944 S2, 993 Carrera, 993 C2S (2), 996.1 C2 Cab, 996.1 C4, Boxster, Boxster 'S' (3), 996.2 Carrera
Present: '01 996 Turbo, '03 996 Carrera 4 'S', '99 Boxster 'S', '17 520D M Sport, '89 Mini 30
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Sat Apr 14, 2018 8:32 am    Post subject: Reply with quote
Pickse,when are you at Spa, I am going to the classic over the weekend of the 20th ( in my BMW)
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
Pickse
PostPosted: Sat Apr 14, 2018 8:53 am    Post subject: Reply with quote
Same here, we're going out on Friday the 18th with Longers (Fasttrack Tours) staying at Hotel Verviers.
I'll pm you my mobile so we can stay in touch.
I'll also bring a mirror on a stick so everyone can admire my new turbos Laughing
Pickse
