997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sat Jul 07, 2018 7:32 pm    Post subject: Reply with quote
Top work, it is looking great.
Dammit
PostPosted: Sun Jul 08, 2018 7:01 am    Post subject: Reply with quote
Impressive stuff.
Jamesx19
PostPosted: Sun Jul 08, 2018 7:50 pm    Post subject: Reply with quote
Thanks MC / Dammit,
Lessons for anyone else attempting this in a similar fashion are:
1.) Get a jack that lifts to at least 530mm - essential.
2.) Raise the car to at least 550 mm under rear Jack points, and 850mm under the rear cross member, otherwise you'll be in a world of pain getting the engine out from under the car without having to remove bits of intake manifold first.
3.) A crane hoist works well....
4.) Secure the gearbox to the Jack when lifting or lowering the engine and gearbox together as the lot will tilt if you only use a block of wood like I did....
5.) The gearbox is a heavy SOB! How ELA and Infrasilver manage to remove it on the floor of their workshops is a great feat of strength and ingenuity! (Edited for spelling mistake!)
Will update when running.....
1998 C2 Manual + The Full Hartech.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Jul 09, 2018 9:24 am    Post subject: Reply with quote
Not really noticed mine ticking at low idle. Maybe because I use 10w40 Millers rather than 5w40 Mobil? Shouldn't be much different when hot though.
The aircon compressor is hard to get out when its in situ if you have never done it before because the rear bolt is hard to find.
But putting one in is easy as you can see where the bolt needs to be, but you can't see the bolt with the compressor in. When mine failed I whipped it in and out several times (out to see if it failed, in to drive around while new one came, out swap for new one bit not hook up pipes, in to drive to air con specialist, out to clean out the line sand hook up, and finally back in to recharge the system). So by the time Id finished I could do it with my eyes closed.
Marky911
PostPosted: Mon Jul 09, 2018 10:12 am    Post subject: Reply with quote
Brilliant work James. worship
Nearly there now. Thumb
My Indy always recommends having the air-con on as the engines are much happier at tickover.
You're also telling me Demort does house calls now?? I think I might need to relocate down south. Very Happy
Good work Demort, as ever.
BHZ661
PostPosted: Mon Jul 09, 2018 10:42 am    Post subject: Reply with quote
Fantastic work , thumbsup
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Jul 09, 2018 12:32 pm    Post subject: Reply with quote
Glad to see it pushed back home and hopefully you'll have it back up and running soon.
How many miles have been recommended for the running in period?
Jamesx19
PostPosted: Mon Jul 09, 2018 8:20 pm    Post subject: Reply with quote
Cheers for the comments....
Wasz - a new compressor is £180. Not sure it's that, but looks like it's been leaking from a pressure relief valve thing on the side of the housing. Can't see leaks from anywhere else, so I'll give it a go.
Marky - Roads are better ooop north I reckon, but no DeMort on demand!!!
Infrasilver - running in, basic oil 20-30 mins - 20 -30 miles. Not babied and not thrashed or laboured, but something in between to bed in the rings. Brisk, shall we say?
Change oil and filter. (Don't look at it, I'll panic!) Then 2000 miles on a semi synthetic, driven robustly not red lined or full chat by any stretch. Change oil and filter Miller's nano+ good to go.....
If the rings are not bedded in in first 20 mins, then they may polish the honing making the running in process much longer....
That is my understanding anyway.
Couldn't find a cheap mineral oil I liked so have Miller's CRO competition running in oil. Under £40 for 10 litres from Opie Oils.
asterix_the_gaul
PostPosted: Tue Jul 10, 2018 6:37 am    Post subject: Reply with quote
A whole load of stuff about a rebuild run in I never knew which might be of interest.. http://www.enginebuildermag.com/2014/10/break-in-oils-and-assembly-lube-needs/
Jamesx19
PostPosted: Tue Jul 10, 2018 6:56 pm    Post subject: Reply with quote
Interesting article. Thanks.
Lots of opinions and things to think about isn't there?
[/b]
Jamesx19
PostPosted: Thu Jul 12, 2018 8:13 am    Post subject: Reply with quote
Still not had a chance to start her up yet.
Just a note to say, following a conversation with Grant. The Miller's CRO running in oil maybe a bit aggressive for my needs. The bores are already plateau honed and brushed. So will source some straight mineral oil.My local motor factor has 10w30 Granville Hypalube. So will go with that for the first 20 mins or miles.
Cheers to Asterix again for the article. Reading that and speaking to Grant has given me a better appreciation for what's required
Bluebird911
PostPosted: Thu Jul 12, 2018 9:10 am    Post subject: Reply with quote
Great thread, excellent work! Thumb
Jamesx19
PostPosted: Sat Jul 14, 2018 6:40 pm    Post subject: Reply with quote
Cheers Bluebird.
Blasted thing won't start!
No fuel at the fuel filter. I did pull the fuel pump fuse to give it a 5 sec crank to check oil pressure. Replaced, but no fuel coming through. I've closed everything. Locked, unlocked several times, in case it's an imobiliser on the alarm system, but no luck.
Any thoughts? Cheers
PostPosted: Sat Jul 14, 2018 6:47 pm    Post subject: Reply with quote
sent you my number via pm
Indy Mechanic .
Jamesx19
PostPosted: Sat Jul 14, 2018 8:14 pm    Post subject: Reply with quote
Ok, were starting with checking the fuel pump........
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sat Jul 14, 2018 8:19 pm    Post subject: Reply with quote
Can you check fault codes as crank sensor could be an issue?
Jamesx19
PostPosted: Sat Jul 14, 2018 8:58 pm    Post subject: Reply with quote
Hi Infra, thanks,
Only have a cheap code reader. But it connects. Showing no DTC or I/m codes.
It is a possibility, as we snagged the crank sensor wire getting the engine out. I did check it for continuity, which was ok. Pin 1 to Pin 3. Resistance was around 950ohms which was a little high I thought.
DeMort thinking fuel supply should not be dependent on getting a crank signal, so trying fuel pump first.
I'll get it out and bench test it.
Do we think 5 months without use may have seized the pump? I'm sure I saw a post saying someone had encountered a similar issue in the same circumstances.??
Jamesx19
PostPosted: Sat Jul 14, 2018 9:07 pm    Post subject: Reply with quote
Just found this:
http://911uk.com/viewtopic.php?t=125251&highlight=fuel+pump
Might help. Will try and jump the relay to check the pump pumps!
thecarfixer
PostPosted: Sun Jul 15, 2018 2:28 pm    Post subject: Reply with quote
You should get a few second pump prime without having to crank the engine when you first turn the ignition on, do you?
Jamesx19
PostPosted: Sun Jul 15, 2018 3:43 pm    Post subject: Reply with quote
Hi Carfixer,
No, but then I have never heard a pump come on that I remember.
Is there anyone with an early cable throttle 996 that can answer that one?
Fuel pump seems ok. I used a jumper wire across the relay pins which switched the pump on. I could hear it running which it didn't before, and there is now fuel in the injector rail which was dry.
I tested the relay with multimeter and a fused jumper wire onto the battery. I could hear it clicking.
Is there a pressure switch in the fuel system? If not, I can't see that the pump would prime then cut off until the engine cranks?
Crank sensor next? The tachometer never flinched when cranking. Or something else you reckon?
Cheers Jim
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Page 6 of 9
