apollokre1d said:
Phil 997 said:J, When you go to the OPC you need to give them very clear instructions. tell them to turn on the multifunction option, you will need to insist as they will think they know better and not do it as it hasn't got MF . this will sort your horn problem. Do not let them charge you more than 30 mins labour.
if the horn sticks when depressed remove the air bag and add a small amount of silicon grease to the three tabs on the side of the airbag.
If the airbag goes down and doesnt return then you need two new springs at the bottom they are about £1.30 each
The refurbed wheel looks great by the way. :thumb: :thumb:
-- 997 -- said:Phil 997 said:J, When you go to the OPC you need to give them very clear instructions. tell them to turn on the multifunction option, you will need to insist as they will think they know better and not do it as it hasn't got MF . this will sort your horn problem. Do not let them charge you more than 30 mins labour.
Hi Phil. Yeah thanks I'll have that in mind when I get there tommorow morning :thumb:
I'm just bloody hoping the coding is all that's needed and not the.module!! If the module is needed Is it easy to fit it? Also what does this module look like and where is it located?
Regards to the horn sticking, doesn't do it anymore I did purchase new springs and retracts back nicely!! But will add some silicone grease to the 3 tabs where the horn glides against it for ease of the horn.. etc..
J
