Not used it much over winter but when starting it, it will fire but instantly stall unless I keep it going with throttle, after about 15 secs its perfect. Feels like its starting on a couple of cylinders then the rest join in. Is this common? only just started doing it, but then again I normally use it more often.
My random thoughts are plug fouling? coil packs are good, or fuel pressure?.
