997 : 2004- 84
996 : 1997-2005 45
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Mar 13, 2018 12:44 pm    Post subject: Brake pads replacement... DIY noob part 2 Reply with quote
Following on from the successful replacement of discs, I now think I need to do the pads after all as they were more scored than I'd hoped on the inside pair. I'm happy with the process of taking them out and replacing.
Some questions-
- Can I reuse the damping shims?
- where do I put the anti-squeal copper grease?
Any other hints and tips as always gratefully received...
TIA.
Robertb
PostPosted: Thu Apr 12, 2018 3:31 pm    Post subject: Reply with quote
An update in case anyone refers to the thread in future...
- Yes you can reuse the anti vibration shims. I gently pinged them off with a Stanley knife, and just replaced them in the calipers. I did not bother to put any adhesive on as the clearance between the pads and the pistons is tight anyway, and one pair of shims fell off as I removed the old pads so clearly weren't attached to the pads anymore. No squeals so far.
- I put the grease (I was recommended to use Ceratec) on the corner of the pad surround where it rests on the guide pins on on the caliper.
Other things-
I put ceratec on the retaining pins when I replaced them, to make their removal easier next time.
I had to remove the calipers to get out the old pads, which had the anti-vibration shims attached to them. Easily done, only two hex bolts.
All in all, discs and pads are an easy and satisfying DIY job for a noob that will save £££.
