997 : 2004- 84
996 : 1997-2005 45
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
elwyn
PostPosted: Tue Mar 13, 2018 8:59 am    Post subject: air con fan Reply with quote
hi, started 996 carrera yesterday and noticed only one radiator fan working, have been advised its resistor that works first stage speed , this is the metal tube that sits in the clips at the bottom of the radiator?, has anybody done this repair? and where do i order one? thanks for reading, regards to all
alex yates
PostPosted: Tue Mar 13, 2018 9:33 am    Post subject: Reply with quote
They're quite expensive. If you can DIY, search on here for RS ballast resistor for a cheaper fix.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Mar 13, 2018 11:56 am    Post subject: Reply with quote
Is the fan working at all? I only ask as mine doesn't work and I assumed it to be a resistor, in fact its the fan that's gone so worth checking.
For a C2/4, a new OE spec fan is not too expensive from car parts 4 less, it seems to include a resistor, and is not a lot more than a new resistor from design911.
