997 : 2004- 84
996 : 1997-2005 45
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
k11pol
PostPosted: Sun Mar 11, 2018 4:41 pm    Post subject: Amount of air con gas required Reply with quote
I have just replaced the 2 condensers on my 2006 C2s. The front end has been removed for a respray so I had a look at the condensers and decided to replace them while they were freely accessible and after inspecting them it was clear to see that they were deformed in the areas where debris has destorted the fins to a point that if I held a torch at one side you could barely see the light coming through so would suggest the air flow wouldn’t flow so easily either. It was also an ideal opportunity to clear all those leaves and dirt from the surrounding area.
My question is does anyone know the correct volume of gas to re fill it with ?
PostPosted: Sun Mar 11, 2018 4:57 pm    Post subject: Reply with quote
900 grams R134A .
If the system has been open to the air for a while ( 24 hrs ) then you should replace the dryer as well .
If both condensors have been replaced then thats about 15 ml of pag per condensor that needs to be added .
The place thats refilling should have the details ?
At an Indy these days !
k11pol
PostPosted: Sun Mar 11, 2018 5:18 pm    Post subject: Reply with quote
Nice one, thanks for that
