997 : 2004- 93
996 : 1997-2005 44
964 : 1989-1993 4
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 8
Macan : 2014- 0
CamGTS
PostPosted: Sun Mar 11, 2018 4:38 pm    Post subject: lost all brake fluid! Reply with quote
fired up my 997GTS after a 2 month hibernation and got to the end of the road and brake pedal felt mushy, then went all the way to floor and brake fluid warning light came on and no brakes! Fluid now dripping from the middle of the undertray so look like a brake pipe has gone. It's off to OPC Edinburgh tomorrow but I find it difficult to understand how a brake pipe could fail on a 7 year old car that has full OPC history service. Are underside brake pipes a known issue?
Cam
911 GTS 2011
Porsche Macan GTS 2016
Renaultsport Clio 182 2004
Talbot Sunbeam Lotus 1980
Chrysler Sunbeam 1.6S 1977 - gone but never forgotten
Yamaha MT-09 2015
PostPosted: Sun Mar 11, 2018 4:49 pm    Post subject: Reply with quote
They are on 996 , not seen any 997 fail so far but have seen corrosion on the pipes .
The pipes run up the n/s and under the undertrays .
I expect its corroded through in one of the brackets , they tend to hold moisture and a good waxoil of the pipes on any car is a sensible precaution .
OPC dont waxoil pipes , indys do it on a majour service though .
CamGTS
PostPosted: Thu Mar 15, 2018 10:09 pm    Post subject: Reply with quote
Porsche warranty covering this which is just as well as it is engine/gearbox out job to replace corroded brake pipe
Cam
911 GTS 2011
Yamaha MT-09 2015
monster
PostPosted: Fri Mar 16, 2018 1:51 am    Post subject: Reply with quote
Mine went in exactly the same manner a few years ago, seemed to have corroded through at the point where it sits in the clip. I wrote this thread at the time:
http://911uk.com/viewtopic.php?t=116076&highlight=braking
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Mar 16, 2018 7:26 am    Post subject: Reply with quote
I've just replaced the same pipe on my 19 year old 135k 996.
The old one was still going strong!
Surprised to hear of one going on a 7 year old car!
I would have them check all the other steel lines, especially NSR and OSF around the steering rack.
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
