996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
pye21
PostPosted: Wed Mar 07, 2018 1:23 pm    Post subject: OE Becker iphone connection Reply with quote
Im looking at options for connecting my phone to the OE fit Becker in my 99 Carrera. Im not fussed about bluetooth for calls, im more concerned about connecting the phone to play music and charge it.
I have searched on here lots, but not come up with anything clear.
Has anyone tried the Xcarlink kit?
https://www.ebay.co.uk/itm/Xcarlink-SKU3895-Aftermarket-Becker-CD-head-unit-iPod-iPhone-interface-adaptor/171002224009?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
I tried one of the cable only connections into the CD changer port and it didnt work. It will charge my phone, but wont play any music.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Wed Mar 07, 2018 8:59 pm    Post subject: Reply with quote
I use one of these:
https://www.ebay.co.uk/itm/191476922546
And one of these:
https://www.amazon.co.uk/Besign-BK01-Bluetooth-Hands-Free-Streaming/dp/B01MSUWCZ0/
Hardwired to this:
https://www.ebay.co.uk/itm/253414738181
No wires, no fuss.
What happened with your aux wire? did you turn aux on in the menu?
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
pye21
PostPosted: Thu Mar 08, 2018 1:28 pm    Post subject: Reply with quote
It will charge the phone, but the headunit doesnt pick up the sound through the jack plug.
This is what i have.
https://www.ebay.co.uk/itm/Audio-Input-Cable-Adapter-for-Porsche-Becker-with-iPhone-5-6/141854421935?hash=item21072eb3af:g:pzoAAOSwLVZV3tPG
What menu does it need turning on in?
asterix_the_gaul
PostPosted: Thu Mar 08, 2018 11:10 pm    Post subject: Reply with quote
Covered in this thread http://911uk.com/viewtopic.php?p=761710
kas750
Reims
2006 Porsche 911
PostPosted: Fri Mar 09, 2018 6:04 am    Post subject: Reply with quote
I have used one of these for the last two years and it is truly brilliant. thumbsup
https://www.ebay.co.uk/itm/TeckNet-Bluetooth-FM-Transmitter-Car-Kit-Wireless-Sound-Transmission-With-USB/112336279857?epid=2260615350&hash=item1a27c39931:g:XioAAOSwtfhYtfyb
Tobyone
PostPosted: Fri Mar 09, 2018 7:40 am    Post subject: Reply with quote
Guys so you are saying this will fit my 997 gen 1 with the standard BOSE OEM system?
It does not have the multi cd changer fitted so the socket for cables will be there ready? Dont know
997.1 C4s GT Silver, factory Aerokit
asterix_the_gaul
PostPosted: Fri Mar 09, 2018 11:33 am    Post subject: Reply with quote
There are several different solutions we are discussing on this thread: the Bluetooth cigar lighter FM transmitter which kaz750 linked to works on any car as it takes the Bluetooth signal them transmits is as an FM radio signal which the car radio then picks up like A normal radio station.
the sound quality of an FM transmitter will not be as good as direct cable connection but I can't comment in absolute terms as I have not tried a decent quality one, it might well be OK for you, and they are pretty cheap and instant to fit so maybe worth a try.
The cable solutions I don't know as I'm not familiar with the 997 setup.
asterix_the_gaul
PostPosted: Fri Mar 09, 2018 12:04 pm    Post subject: Reply with quote
I'm trying much the same solution as wasz, but a direct hard wire, car in bits at the moment so not completed this little project yet, but intending to pull power off the CD changer mini iso to hook up the Bluetooth thing using the following bits I ordered a few weeks back
https://en.m.wikipedia.org/wiki/Connectors_for_car_audio
Guide to iso connector and a voltmeter!
[/url]http://www.ebay.co.uk/itm/360549086402[url]
Changer plug with rca sockets
[/url]http://www.ebay.co.uk/itm/122954239257[url]
Hardware Bluetooth thing with rca's
[/url]http://www.ebay.co.uk/itm/360864050246[url]
And some pre wired pins to pick up the power direct from the head unit..
pye21
PostPosted: Mon Mar 12, 2018 1:21 pm    Post subject: Reply with quote
That worked a treat, cheers. Cable connection now works and does exactly what i want!
I had know idea the Aux had to be turned on, expected it would work straight away as the CD changer had before hand.
asterix_the_gaul
PostPosted: Wed Mar 21, 2018 8:02 pm    Post subject: Reply with quote
Just checking, can you guys turn on your becker cdr22 without the keys being in the car? I.e. it has a constant 12v feed?
Finally got all my bits and my voltmeter and some time so managed to locate a 12v output from the CD changer socket, but it's constantly live and I need a switched one for the hardwire Bluetooth so might have to chop into the loom which is irritating, unless I can find another pin which is switched 12v, there must be one..
matt_SM
PostPosted: Thu Mar 22, 2018 8:38 pm    Post subject: Reply with quote
Hi, I have the CDR-23 but with no amplifier, CD changer or door speakers (my car is a club sport GT3). The CDR-23 was also constant live, with no MOST but connected to the HVAC via the BUS.
Long story short, I spliced a constant live from the HVAC (blue and black cable).
Matt
matt_SM
PostPosted: Thu Mar 22, 2018 9:02 pm    Post subject: Reply with quote
Sorry, that should read ‘spliced a REMOTE live’ from the HVAC Grin
