Boxster : 1997- 25
PostPosted: Sun Oct 07, 2018 3:53 pm    Post subject: Reply with quote
When a fuse blows straight away then its normally a dead short in the wiring or the item .. in this case the horns.
I would tend to unplug the horns and put another fuse in , if it doesnt blow then one or more of the horns is faulty.
If it does then your into traceing the wiring to find the short or just running new wires .
thesmithsUK
PostPosted: Sun Oct 07, 2018 3:55 pm    Post subject: Reply with quote
Many thanks for the quick, helpful response - will give that a go (after the Liverpool v Man City game!).
1990 964 C4 Cab | Manual | Brilliant Red Metallic on Black
1984 Ferrari Mondial QV Coupe | Manual | Argento Silver on Bordeaux
1984 924 2.0 | Manual | Black on Black
Ex 2004 996 C4S | Manual | Seal Grey on Black
Ex 1991 TVR 450 SEAC | Manual | Cureton Green on Tan
thesmithsUK
PostPosted: Sun Oct 07, 2018 5:56 pm    Post subject: Reply with quote
Sorted.
Took the horns off, re-connected them, put a new fuse in - bingo!
Guess one of the spade connections might have worked loose?
Anyway, now working again - thanks Iain.
PostPosted: Sun Oct 07, 2018 6:17 pm    Post subject: Reply with quote
Its working is the main thing .. if one of the wires had come off the horn and was touching the bodywork then that would cause this issue .
For now just keep an eye on it .. it might still be a horn failure but time will tell Smile
MaKSiNG
PostPosted: Thu Oct 11, 2018 8:35 am    Post subject: Reply with quote
Sorry for the newbie question Dont know
So we have 2 horns in there which obviously both make slightly different sounds simultaneously when the horn button is pressed.
I have the symptom that I have and have always had a really wimpy horn (I just thought this was normal) and I was actually always quite embarrassed to press it unless really necessary frustrated
Does this sound like one of the 2 horns is simply not working?
PostPosted: Thu Oct 11, 2018 5:59 pm    Post subject: Reply with quote
It does .. you can also get one horn inop and the other partially fail which basically means you get a wierd sound out of it .
not just 964 type horns .. ive seen similar on all Porsches .
MaKSiNG
PostPosted: Mon Oct 15, 2018 5:45 pm    Post subject: Reply with quote
Nice, thanks for the reply.
Another thing for the list to check out when I get some time.
thumbsup
Goto page Previous  1, 2
Page 2 of 2
