996 : 1997-2005 29
Boxster : 1997- 14
thesmithsUK
PostPosted: Sat Mar 03, 2018 5:07 pm    Post subject: Failed spoiler motor? Reply with quote
Rear spolier has been playing up.
Was working intermittently. Occasional warning light on dash. But hasn't worked for a couple of weeks.
So...I disconnected the gear mechanism from the motor. Tested it via my variable speed drill. Went up and down OK, though not as quiet as it should be. So I did the new 'ball bearing' fix courtesy of: https://www.bergvillfx.com/spoilerrepair/
It now goes up and down (when I power it from my drill) silently. So far so good.
But the motor won't power it! Is there an easy way to test the motor? (Related fuse is fine btw.)
Replacement ones seem to be north of £300!
1990 964 C4 Cab | Manual | Brilliant Red Metallic on Black
1984 Ferrari Mondial QV Coupe | Manual | Argento Silver on Bordeaux
1984 924 2.0 | Manual | Black on Black
Ex 2004 996 C4S | Manual | Seal Grey on Black
Ex 1991 TVR 450 SEAC | Manual | Cureton Green on Tan
PostPosted: Sat Mar 03, 2018 5:42 pm    Post subject: Reply with quote
Isn't the spoiler linked to a ABS speed sensor on the rear left wheel? Could be a dirty contact?
Does your speedo work OK? Check R52 in the fuse box
Some info here:
https://rennlist.com/forums/964-forum/854883-another-964-spoiler-thread.html
thesmithsUK
PostPosted: Sun Mar 04, 2018 8:59 pm    Post subject: Reply with quote
Speedo works fine. Fuse OK.
I'm wondering whether it's a problem with the motor, or with the spoiler control unit underneath the dash...
Chief
PostPosted: Sun Mar 04, 2018 9:21 pm    Post subject: Reply with quote
Have you checked the micro switches?
- 964 C2 The Red Baron - 914 2.0 Project Blue Book - Cayman S Sport Edition Amber Alert! -
Instagram - @chiefporsche
thesmithsUK
PostPosted: Mon Mar 12, 2018 8:04 pm    Post subject: Reply with quote
The motor is toast. Tested it via a spare 12V battery - nothing.
I know you can open them up and refurbish, but life's short...
So I've bought a very reasonably-priced, used replacement from a fellow Rennlist-er in the US.
Should be here in a couple of weeks - will report back!
thesmithsUK
PostPosted: Sun Mar 18, 2018 11:51 am    Post subject: Reply with quote
Just fitted the replacement motor - bingo, works perfectly!
