997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
thesmithsUK
PostPosted: Sat Mar 03, 2018 1:23 pm    Post subject: Engine Bay question: what's this?! Reply with quote
Noticed a loose, clear tube in my engine bay this morning. Anyone know what it's for?!
Looks like it should connect as in this picture (circled in green) from the web:
(Image from the web, btw - not my car.)
1990 964 C4 Cab | Manual | Brilliant Red Metallic on Black
1984 Ferrari Mondial QV Coupe | Manual | Argento Silver on Bordeaux
1984 924 2.0 | Manual | Black on Black
Ex 2004 996 C4S | Manual | Seal Grey on Black
Ex 1991 TVR 450 SEAC | Manual | Cureton Green on Tan
pzero
PostPosted: Sat Mar 03, 2018 3:04 pm    Post subject: Reply with quote
Tail light vent tube?
KP964
PostPosted: Sat Mar 03, 2018 3:16 pm    Post subject: Reply with quote
There are two tubes I think the other end should plug into the distributor cap , or the vent tube , there is a slot in the side of the distributor cap (front side ) plug it in .
Stone Grey Metallic 964 C4
Guards Red 964 C4 sold
thesmithsUK
PostPosted: Sat Mar 03, 2018 5:11 pm    Post subject: Reply with quote
Closer view:
KP964
PostPosted: Sat Mar 03, 2018 5:36 pm    Post subject: Reply with quote
you can see where it goes in that photo Thumb
thesmithsUK
PostPosted: Sat Mar 03, 2018 5:47 pm    Post subject: Reply with quote
Yeah, have connected it up - just wondered what it's for?!
KP964
PostPosted: Sat Mar 03, 2018 6:56 pm    Post subject: Reply with quote
I think just breather pipes , warm air , one to stop the rear lights from steaming up and the other see here .. https://rennlist.com/forums/964-forum/22689-distributor-vent-kit-do-you-really-need-to-use-the-hose.html
thesmithsUK
PostPosted: Sat Mar 03, 2018 7:02 pm    Post subject: Reply with quote
Many thanks
MidWansbeck
PostPosted: Thu Mar 28, 2019 7:48 pm    Post subject: Reply with quote
Pretty sure that's a vent tube for the distributor. It was a fix due to a thought that ozone buildup in the dizzy was causing the toothed belt driving the 2nd dizzy to fail.
Adapt, improvise and overcome...
964 C4 Coupe and Gutbrod 1032
Diddi
PostPosted: Thu Mar 28, 2019 11:28 pm    Post subject: Reply with quote
correct, should avoid ozone destruction to protect the belt, today rusted bearings are the greatest danger for the Dizzy function and engine misfiring
Grüsse, Diddi
ras62
PostPosted: Fri Mar 29, 2019 10:24 am    Post subject: Reply with quote
see post 4
https://rennlist.com/forums/964-forum/374689-distributor-vent-kit-not-installed.html
thesmithsUK
PostPosted: Sat Mar 30, 2019 5:42 pm    Post subject: Reply with quote
Ah, that makes sense! Thanks all.
