I didn't realise a spanner fits over, I'm worried if I try mine they will disintegrate lol.ragpicker said:The actuator is the bit with the long thin metal shaft which goes through the end of the waste gate and attaches with bolts. These are easy to change/replace.
The actual waste gate is a flap inside the turbo and has an arm outside the turbo which the actuator connects to. They are notorious for seizing where they go through the body of the turbo - usually on the passenger side as this turbo is lower and comes into contact with more crud/salt than the offside one.
As Demort says, a blow torch/oxyacet torch and a 17mm spanner (which slides perfectly onto the arm), plus plenty of lubricant, are a good stop-gap measure.
Once they start to corrode inside the turbo body I'm afraid its only a matter of time before the turbo needs to come off and be sent for refurb.
I had it happen on my original turbos. Then it happened within a few months of putting my hybrids on - I had to send it back for replacement under warranty. Now I get under the car with some WD40 and the 17mm spanner after each day I've driven it to give it a wiggle to keep it free.
:thumb:
:thumb:
Demort said:OPC dont send them for refurb .. they just replace if it doesn,t come appart
I know ... sigh .. not proud of every job i have done .. but im still honest
plynchy said:Demort said:OPC dont send them for refurb .. they just replace if it doesn,t come appart
Are you saying don't refurb the turbo?
I've had the Cossie unit refurbished a few times over the years, always came back looking brand new for a fraction of the cost of a new one.
Demort said:996 is a mechanical system for wastgate control .. 997 is the electric system .
Yup .. i had to replace a turbo for this once many years ago .. when they seize they really do seize ..
Heat is your friend here .. plenty of heat !
couple of picts i found ...
Robertb said:plynchy said:Demort said:OPC dont send them for refurb .. they just replace if it doesn,t come appart
No, he's saying an Official Porsche Centre don't send them for refurb, as opposed to the OP...
