997 : 2004- 77
Boxster : 1997- 15
Cayenne : 2003- 3
Tim996c4
PostPosted: Sun Jul 22, 2018 3:38 pm    Post subject: Reply with quote
Well, had a 130 mile each way trip to sunny Dorset on Thursday for TG to fit 200cell cats, valved boxes, and new lambdas, to replace my leaky old PSE. Great team, product, and service, and well worth the visit to their HQ.
Not sure quite how knackered my PSE was or if the valves were working or not, but the difference is astounding. The guys connected it to the existing switch, so it is now always loud unless I press the button. And LOUD it is! It sounds brutal under any level of acceleration, and hit 5k and she screams... kept it on loud all the way home, but on the M5 cruising at 70ish in 6th, it is not intrusive or droning, then give it a bit of gas and the low pitch roar is addictive. Switch to quiet mode really does cuts down the noise by a significant amount but still sounds nice - great for not annoying the neighbours too much.
Overall, very pleased with the set up and the service that I received from TopGear.
Many thanks to Alex for the group buy discount, it makes it an even sweeter purchase.
PostPosted: Sun Jul 22, 2018 3:43 pm    Post subject: Reply with quote
great review Tim Thumb Thumb Thumb
rdodger
PostPosted: Sun Jul 22, 2018 3:48 pm    Post subject: Reply with quote
Did you go for the straight cats or the X version?
Tim996c4
PostPosted: Sun Jul 22, 2018 7:42 pm    Post subject: Reply with quote
Standard x-over cats
Tim996c4
PostPosted: Sun Jul 22, 2018 7:44 pm    Post subject: Reply with quote
That's probably not clear....
Cats are the same configuration as standard, so they cross over each other. Hence the one on the left exits on the right and vice-versa.
Paddcomp
PostPosted: Sun Jul 29, 2018 10:12 am    Post subject: Reply with quote
Anyone here running a 987.1 3.2 with 200 cell cat manifolds and a valvetronic exhaust from Topgear? Thoughts on noise with valves open and closed, any noticeable power gains?
NLW73
PostPosted: Tue Jul 31, 2018 6:48 pm    Post subject: Reply with quote
alex friend of mine just got a 997.1 3.6 and after some mild sports mufflers if you have some in stock and anything you can do discount wise?
PM on its way. nick
997 C2s Schwarz
gordyhutt
PostPosted: Fri Aug 03, 2018 7:12 pm    Post subject: New Exhaust System Needed Reply with quote
hi all, have been keeping an eye on this thread as I knew I was going to need a new system for my 996 C4 tip. Car is relatively new to me but it's had a few issues. The time has come, as the engine is now out, to invest in a new headers back system. I saw the TG system when I was looking for a Dansk replacement but the positivity for TG really has convinced me to go after one.
Current set up is stock and I like the sound but would like a little more. I suspect the full sports set up might be too much for a daily driver so was planning on manifolds, 200 cell sports cats (not x) and mild sports silencer.
Any opinion on how close to stock sound this is? Too quiet, just right? I know, personal taste but it's daily driven so want something nice but not too loud.
Thanks from first time poster.
G
PostPosted: Fri Aug 03, 2018 7:20 pm    Post subject: Re: New Exhaust System Needed Reply with quote
G
Welcome
Go big or go home Grin
Say bye in the Newbie area Thumb
taffybloke
PostPosted: Sun Aug 05, 2018 6:54 pm    Post subject: Re: New Exhaust System Needed Reply with quote
G
Why not get the valved silencer's then you can turn the noise up or down when required.
Mike
gordyhutt
PostPosted: Sun Aug 05, 2018 8:01 pm    Post subject: Reply with quote
That is a very good point.
I'm wary as its a reasonably complex set up and I don't have PSE just now.
Would love to hear comment about reliability but then there's the additional cost...given I've some current engine woes.
It's now on the list for consideration tho.
996 C4 tiptronic 2004
M444TTB
PostPosted: Tue Aug 14, 2018 8:41 pm    Post subject: Reply with quote
Finally had my rotten (but correctly functioning - valves replaced a couple of years ago) PSE with the valves back boxes and the 200 cell X-pipes. With the valves closed it’s pleasingly almost exactly as standard. No droning and maybe a tiny bit more bass. Valves open is a different story. It was quite fruity with the PSE. Now it’s borderline antisocial if you put your foot down. I drove it in first and second gear traffic with the windows open for the last couple of miles taking it home tonight and my ears haven’t felt like this since I sold my Westfield! Can’t wait to hear it on a proper cold start up next time I take it out.
Only thing I now need to sort is a new tip for the near side. The Bolt was knackered so they couldn’t adjust it to match position with the other side and it doesn’t look quite so good. Not sure what what to do there other than not give Porsche etc £250 for one side!
Thefinn
PostPosted: Tue Aug 14, 2018 9:37 pm    Post subject: Reply with quote
What car is it M444TTB it might be the ring inside the tip rather than the bolt itself and we have a man making replacements for the 997 which i much cheaper than replacing the whole thing.
997.1 C4S CAB
PostPosted: Tue Aug 14, 2018 9:44 pm    Post subject: Reply with quote
Its not really complicated they fitted valvetronic to my gen1 and I controlled it with an on off fob . they also offer fitting if your near Bridport Dorset or have franchises all over the UK longlife and powerflow Thumb
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Wed Aug 15, 2018 7:54 am    Post subject: Re: New Exhaust System Needed Reply with quote
G
I'm going for the exact same set up except I'm fitting the valvetronic silencers. Like you, I want something not too loud for normal jogging (until I open the valves that is Very Happy).
Hopefully I will have the system fitted by the end of the month and I'll let you know how it sounds compared to stock. thumbsup
997.1 C4S Meteor Grey Manual
M444TTB
PostPosted: Wed Aug 15, 2018 10:40 am    Post subject: Reply with quote
It's a 996.2 Carrera 4. I'm not 100% sure that I was told that it was the bolt rather than the 'adjustment mechanism' (or something else entirely).
Thefinn
PostPosted: Wed Aug 15, 2018 8:10 pm    Post subject: Reply with quote
Sorry M444TTB I am not sure they are same design as the 997 ones then with the ring inside. Put a thread up on the 996 section I am sure there will be someone who can help, it seems a same to replace them just for one bolt
997.1 C4S CAB
MrC986
PostPosted: Mon Aug 20, 2018 5:46 pm    Post subject: Reply with quote
I've just ordered a pair of "sports sound" boxes to replace a pair of Dansk ones...I'm hoping that they're sufficiently loud enough that I don't need uprated cats for the full effect, though if I do they'll be on the list for the next group buy! I'll post a clip of the noise once fitted for future reference. Fortunately I've not got to wrestle with any grotty/rusty exhaust brackets as my techie kindly swapped them earlier in the year.
PostPosted: Mon Aug 20, 2018 6:20 pm    Post subject: Reply with quote
looking forward to hear the sound byte mate Thumb
heres mine from early 2014 just at the start of my mods with just the valved sports boxes, yours should sound similar to mine when its on loud.
https://www.youtube.com/watch?v=az8rQLPjFfw
and if you decide you need 200 cell cats then heres member shaps car with a valved sports set up with 200 cell cats again on loud thats what yours would sound like.
https://www.youtube.com/watch?v=26fjqA6eUt8
coullstar
PostPosted: Mon Aug 20, 2018 9:08 pm    Post subject: Reply with quote
Got my mild silencers today to go with the 200cel x-pipe fitted earlier in the year.
Goto page Previous  1, 2, 3 ... 16, 17, 18, 19, 20  Next
Page 17 of 20
