997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
JordonMusser
PostPosted: Wed Jul 31, 2019 2:22 pm    Post subject: Reply with quote
Thank you. I will play a bit with further confidence (since my hunches are backed by some of your data).
Since I left the factory ECU in for now I made it easy on myself since the car starts/runs etc.
Eventually I would want to have the Motec transmit required messages so I can remove the factory ECU completely, but then is a few iterations down the road.
The only thing that will speed that up is if ABS requires messages to function (I moved the factory gauge cluster connector to under the dash, so I can plug it in to verify things like ABS/Airbag warnings quickly with out pulling out Durametric. Which I plan to do soon.
Goto page Previous  1, 2
Page 2 of 2
