997 : 2004- 84
996 : 1997-2005 47
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
Beanie
PostPosted: Fri Feb 16, 2018 10:20 am    Post subject: 997.1 Targa 4 Dead Amp? Reply with quote
Hi All
All my bass in the car has gone and I suspect it's the amp that's died? Anone know where the amp is located in a 997.1 Targa 4? In the front luggage area under the bonnet is the CD changer and behind that the Nav DVD, any idea where the amp lives?
Beanie
Beanie
2008 Black 997 Gen1 Targa 4
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Feb 16, 2018 10:44 am    Post subject: Reply with quote
If its like a 996 it will be behind the front luggage area trim at the back by the scuttle, IIRC.
resigner
PostPosted: Fri Feb 16, 2018 11:03 am    Post subject: Reply with quote
When you find it, look up Tore in Norway. He's just fixed mine and gives a 5 year warranty!
Beanie
PostPosted: Fri Feb 16, 2018 11:13 am    Post subject: Reply with quote
That's what I'm planning to do Wink Do you have the web address or details, just to confirm same guy? Thanks
Once I've managed to locate it in the car of course!! Dont know
Beanie
resigner
PostPosted: Fri Feb 16, 2018 12:00 pm    Post subject: Reply with quote
assuming its an ASK amp and not Bose?
this is him
https://www.bergvillfx.com/
Beanie
PostPosted: Fri Feb 16, 2018 12:18 pm    Post subject: Reply with quote
this is him
Yep, same guy Smile
Also, I've got the standard sound pack so I'm guessing it's an ASK.
Beanie
resigner
PostPosted: Fri Feb 16, 2018 12:35 pm    Post subject: Reply with quote
Should be
PostPosted: Fri Feb 16, 2018 12:39 pm    Post subject: Reply with quote
Have you looked in the bit where your toolkit is located in the frunk the bit that comes off that has the red warning triangle on mine was in there nasty small amp easy to miss lol Thumb
Beanie
PostPosted: Fri Feb 16, 2018 1:12 pm    Post subject: Reply with quote
I'll take a look, I'm hoping it is there, thanks for the steer Thumb
Beanie
Riccardo
PostPosted: Mon Feb 19, 2018 10:03 am    Post subject: Reply with quote
The above description (Phil 997) sounds like off a C2. The C4 has a different boot layout with warning triangle on the floor as opposed to the "ledge".
I've had the ASK amp done on my C4S by Tore in 2013. Still working fine. I think it was a lifetime warranty back then.
You will need to slide off that "hook" which is on the bulkhead of the frunk and then unscrew the various screws around the plastic cover. It comes off all as one piece. Give me a shout if you need any help.
2006 997 C4S, Cobalt Blue
Beanie
PostPosted: Mon Feb 19, 2018 2:10 pm    Post subject: Reply with quote
Yep, my triangle is fixed to the floor as you mention, it's a C4 layout for sure. Any pictures or more details you can share where the amp is? As you look in there from the front of the car, the DVD is at the back right and the CD changer is flush to the right side next to it? Any more advice or pictures gratefully received!!
Beanie
PostPosted: Mon Feb 19, 2018 7:32 pm    Post subject: Reply with quote
Try looking under the large plastic cover in the front boot .. handfull of screws to remove to get it off .
large box with wires and cooling fins on it is what you are looking for .
Amplifiers are either behind the toolkit , under the base panel and on the n/s/f or under the plastic panel .
No.7 here shown in 2 different locations .
https://www.deroure.com/diagrams.asp?TBL=2972&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
Bose amp is under the drivers seat
At an Indy these days !
Riccardo
PostPosted: Tue Feb 20, 2018 2:44 pm    Post subject: Reply with quote
Unfortunately I didn't take any pictures at the time. I do recall it was easy, just remove the screws from the plastic cover and then "manhandle" it out. The most challenging part is to remove the connector from the amp, which looks like below (the Ask one, which is very different from Bose).
In terms of location the amp is at the top of the boot, right in the centre. In the pic below, from the nav unit move left and then up to the top, its under there.
Ask Amp
 Filesize:  104.8 KB
 Viewed:  809 Time(s)
 Filesize:  170.18 KB
 Viewed:  812 Time(s)
