oil leak and heavy clutch- a pleasent end
pancobalt
2 May 2015
284
I purchased my car 3 yrs ago with a heavy stiff clutch pedal but perfectly fine working clutch (allegidly they are all like that ).
For the last year, i have had an oil weep from the engine, suspected rear main oil seal . Finally after much debate , porsche extended warranty agreed to repair the oil leak. As the "misting" had turned into a full on drip.
So gearbox removed and i am permitted to assess the components neatly laid on the bench with a very friendly knowledgable patient master tech.
Rms seal dry as a bone. The culpret was the ims seal. And yes on my april 2005 car , i have the later revised ims bearing ( there is a huge nut at the end of the shaft ),
Flywheel sweet , no hotspots or blueing , 50% clutch plates remaining, we tried to look for date stamps on both parts but were unsuccessful .
Pitting found on clutch slave cylinder and clutch fork (release ), so these were both replaced for a reasonable £250 all in, while we were in there.
Well happy with the service from opc byfleet last week. My oil usage should in theory, be less, not major to start with ,and for some reason my clutch pedal feels lighter and not heavy at all.
Byfleet are excellent
124,608
1,442,032
49,038
DD77
