997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Tim_s
PostPosted: Tue Feb 13, 2018 10:31 am    Post subject: Durametric Enthusiast kit with all VINs remaining + adapter Reply with quote
Genuine Durametric Enthusiast lead with all three vins still remaining, in the original box with all the bits it was supplied with and with the adapter cable for older porsches (964 etc). Comes with CD but the latest software can be downloaded on the durametric website.
£399 on Design911 and a further £89 for the adapter lead
http://www.design911.co.uk/fu/prod9183/DURAMETRIC-EASY-Fault-and-ECU-Reader/
£250 + post
rhino-man
PostPosted: Tue Feb 13, 2018 10:52 pm    Post subject: Reply with quote
Could this be upgraded to Pro if not the original purchaser?
2010 997.2 C4S
2001 996 C2 Convertible
John997
PostPosted: Wed Feb 14, 2018 9:48 am    Post subject: Reply with quote
When I spoke to the chaps in the states about this I asked the same question, you can only do this if you purchased it from them directly and had the reciept as well.
I bought mine from Gendan, I asked them this same question and they advised that it might be possible but they would have to look into it.
https://www.gendan.co.uk/category_179.html
Hope this helps
rhino-man
PostPosted: Wed Feb 14, 2018 9:55 am    Post subject: Reply with quote
Hope this helps
Ok cheers, only £299 from them inc vat and delivery.
How come this is unused OP?
2010 997.2 C4S
Tim_s
PostPosted: Wed Feb 14, 2018 11:01 am    Post subject: Reply with quote
Hiya,
rhino-man - that's a good price from Gendan, but that doesn't include the £89 adapter that mine includes, so it's still £140 cheaper to buy this one
The item's not unused but the VINs have been reset and are all available - can demonstrate on the software showing none used if necessary.
Tim
diverzeusy
PostPosted: Wed Feb 14, 2018 11:34 am    Post subject: Reply with quote
If you can 'reset' the vins, then it can be used on unlimited vehicles? Can't it? How can they be reset? And why buy the more expensive unlimited vehicle one? Question
John997
PostPosted: Wed Feb 14, 2018 6:33 pm    Post subject: Reply with quote
You can get the VIN's reset, few methods:
1.. Have the software or ability to access the cable firmware.
2.. Exchange a V1 cable for the newer V2 cable, called an upgrade but this can only be done via Durametric directly and the V2 cable will be a refurbished one - again you have to be the original purchase onwer and have the reciept.
This is what Durametric said when i asked them end of last year.
Tim_s
PostPosted: Fri Feb 16, 2018 10:37 am    Post subject: Reply with quote
Sold! Thanks for the interest.
