997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
Drew1209
PostPosted: Mon Feb 12, 2018 7:14 pm    Post subject: LCA & Eccentric bolts Reply with quote
Having phoned Porsche today about a few bits for my car the parts person advised that when I renew the coffin arms and fit new eccentric bolts I should be renewing the eccentric washers and nuts also, I had intended using the old ones with the new eccentric bolts.
Old one's are off the car no issue's although I did have to cut the eccentric bolts out.
Doe's this sound correct regarding the nut's and washers ?
Halcyon
PostPosted: Mon Feb 12, 2018 7:19 pm    Post subject: Reply with quote
I replaced all the bolts, washers and nuts when I did mine. They're cheap enough.
Word of warning though, the washers / captive disk things can cut into the aluminium side of the frame, making accurate alignment impossible without a bit of welding..
996.2 Carrera 4 Convertible Tip
PostPosted: Mon Feb 12, 2018 7:22 pm    Post subject: Reply with quote
If the old ones are in good condition then you dont have to .. but i would .
APL911
PostPosted: Mon Feb 12, 2018 8:26 pm    Post subject: Reply with quote
It’s just good practice to replace old fixings.
Threads stretch, surfaces corrode etc.
I replaced mine.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Feb 12, 2018 8:35 pm    Post subject: Reply with quote
I fitted new nuts, but reused the washers as there was nowt wrong with them.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Feb 13, 2018 9:48 pm    Post subject: Reply with quote
Same here.
