997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
captain caveman
PostPosted: Mon Feb 12, 2018 6:20 pm    Post subject: Airbag light fault code 20? Reply with quote
Ok so the airbag light is showing on my car. Scanned for the code with a foxwel scanner and it brings up fault code 20 ignition driver.
But from what I've read this code relates to an alarm fault and the airbag bag fault code should be 21.
Anyone able to shine some light on this? And also what is the ignition 20 driver?
PostPosted: Mon Feb 12, 2018 6:35 pm    Post subject: Reply with quote
Fault code 20 will most likely be either the drivers airbag faulty or the clock spring thats faulty ..
Worth removeing the airbag and checking the brown or brown/yellow wire on the caseing hasnt broken off .
EDIT for picts .
 Filesize:  307.83 KB
 Viewed:  756 Time(s)
 Filesize:  131.47 KB
 Viewed:  756 Time(s)
captain caveman
PostPosted: Mon Feb 12, 2018 9:35 pm    Post subject: Reply with quote
I'll have a look at that in the morning. Already have a spare clock spring ready. Just a bit confused by the different fault codes. Thought there was only the one for the clock ring.
PostPosted: Mon Feb 12, 2018 9:54 pm    Post subject: Reply with quote
It seems there are 5 different codes for the same thing .. a bit strange to say the least .
When you remove the airbag have a look at a wire clipped onto the base plate .. this breaks at the connection and im pretty sure it causes this code .. its obvious anyways .
The tool listed is just a resistor .. but im not sure what the resistance is .
captain caveman
PostPosted: Tue Feb 13, 2018 11:19 am    Post subject: Reply with quote
Nice easy free fix for once, The yellow plug on the airbag wasn't pushed all the way in.
