996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Cybot7
2001 Porsche 996 Carrera 2
PostPosted: Mon Feb 12, 2018 5:37 pm    Post subject: Radio interference Reply with quote
Today was the first time I’ve done a decent bit of mileage with the radio on and I was very aware of spasmodic interference which I eventually put down to my iPhone. The car is a 2001 996. Apart from either not turning the radio on or turning my phone off is there anything I can do about eliminating the interference?
Nothing is foolproof to a sufficiently talented fool
EGTE
PostPosted: Mon Feb 12, 2018 5:57 pm    Post subject: Reply with quote
Have you got any charging devices in the car, such as for phones?
They can cause problems.
Cybot7
PostPosted: Mon Feb 12, 2018 6:00 pm    Post subject: Reply with quote
Aha. Yes it was connected for charging att.
gilessav
PostPosted: Tue Feb 13, 2018 11:51 am    Post subject: Reply with quote
You've not got an aftermarket HID upgrade kit have you? my radio is perfect until the main dipped beams are on and then total distortion, apparently HID kits can cause this and mine is the same.....
Previously LHD 964
Currently 2004 C4S
Cybot7
PostPosted: Tue Feb 13, 2018 11:55 am    Post subject: Reply with quote
No. I’ve come to the conclusion having read about it and what I’ve been told is that the problem lies with the crap charger I’ve been using so I’ve bought a better spec USB charger. Hopefully that’ll cure the problem.
iceboy
PostPosted: Tue Feb 13, 2018 3:09 pm    Post subject: Reply with quote
Giles, I have this exact problem!!
Is there anything that can be done?
IceBoy
Dont know
Current cars:
996 Turbo S - Coupe/Manual
996.1 Carrera 2 - Couple/Manual
Mercedes S320 CDI - Every day car
BMW 320d M-Sport Plus - Mrs. Ice
VW Golf GTI 8v Big bumper - Summer Toy
gilessav
PostPosted: Tue Feb 13, 2018 8:05 pm    Post subject: Reply with quote
Not sure.....
have new HID complete kit coming this week as the old ballast one side appears to have failed (just in time for the MOT). some of the advertised ones seem to claim that have some sort of way to avoid the interference but we'll see!
Interestingly HorizonLED's have discontinued the kit I ordered and have new 3 year warranty apparently higher quality kits which are MOT legal coming on so will be fitting that (£30 upscale of costs); will report back on if it makes a difference as nagging annoying!
Previously LHD 964
Currently 2004 C4S
toobusy
PostPosted: Tue Feb 13, 2018 9:44 pm    Post subject: Reply with quote
I have the same problem with phone charger/sat nav charger. I've tried various adaptors but no luck. Interested to see if yours works..
I have read that adding separate power for charging or an additional earth for the radio works!
2003 Carrera 4, KTM, Jota
Ghianightmare
PostPosted: Tue Feb 13, 2018 10:17 pm    Post subject: Reply with quote
I noticed radio interference recently when using a Lidl usb charger adapter in the cigar lighter. Switched to the branded energizer one that I also had in the car and problem disappeared. I have PCM 1
2002 Seal Grey C4S
Ghianightmare
PostPosted: Tue Feb 13, 2018 10:20 pm    Post subject: Reply with quote
2002 Seal Grey C4S
Gottans
PostPosted: Tue Feb 13, 2018 10:38 pm    Post subject: Reply with quote
Easy check is to remove the charger from the lighter socket and see if the problem goes away. If it does then it is most likely the charger.
There is something to be said for buying the oem charger as it 'should' have tested to make sure these sort of things don't happen. Mind you doesn't take much to mess up a radio receiver looking for signals in the microvolt range.
Cybot7
PostPosted: Sat Feb 17, 2018 9:16 am    Post subject: Reply with quote
Problem solved with this
Anker-PowerDrive-Speed-2-Quick-Charge-3-0-39w-USB-Car-Charger
EGTE
PostPosted: Sat Feb 17, 2018 11:47 am    Post subject: Reply with quote
toobusy
PostPosted: Sat Feb 17, 2018 1:35 pm    Post subject: Reply with quote
Aha, thanks.
Cybot7
PostPosted: Tue Feb 20, 2018 7:26 am    Post subject: Reply with quote
I should add after a drive yesterday I discovered that in bad reception areas there is still some interference but overall it's cured the problem
Dammit
Watkins Glen
PostPosted: Tue Feb 20, 2018 8:23 am    Post subject: Reply with quote
I had a chat with a friend of mine about this - he's a research scientist who specialises in electronics, so I understood maybe one word in ten (although that could be his accent, he's from the Midlands).
His belief is that it's a fault in the charger that runs through the common earth with the radio, and that separating the earth circuit would be a good idea even if changing charger to one that isn't sub-standard.
My understanding is that the body of the car is the common earth, and I struggle to see where you'd find another/separate one, but then I don't make the electronics for experimental medical devices, so what do I know?
