997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
Kingb4
PostPosted: Sun Feb 11, 2018 9:42 pm    Post subject: Window wont drop fully Reply with quote
Hello,
Am after a bit of advice....have searched the forum, but havent found anyone with this issue: the drivers window wont go all the way down, it stops 2 inches from the bottom. Its doing everything else fine (it drops 10mm when you open the door and goes back up when you close it etc). Its almost as though the bottom 'stop' is set in the wrong place, could this be possible?
Thanks in advance.
Ben
mt10argyll
PostPosted: Sun Feb 11, 2018 9:52 pm    Post subject: Reply with quote
Has the car had a new Regulator fitted, there are two settings on it,
one for the Boxster and one for the 996
2000 996tt Artic Silver
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sun Feb 11, 2018 10:06 pm    Post subject: Reply with quote
To fix, whip the door card and membrane off and remove the "boxster stop" in the channel the lifter runs in.
Kingb4
PostPosted: Mon Feb 12, 2018 11:49 am    Post subject: Reply with quote
Thanks Both! Thats brilliant advice. I am not sure if its had a new regulator, only just bought the car - cant see any receipt for this (and there are lots of receipts). I will have a look and see if there is a boxster stop left in.
Kingb4
PostPosted: Mon Feb 12, 2018 12:34 pm    Post subject: Reply with quote
Have also just found a video, now I know what I am looking for:
https://www.youtube.com/watch?v=nMzqTlp1kis
Might have a look tonight.....
Kingb4
PostPosted: Fri Feb 16, 2018 6:32 pm    Post subject: Reply with quote
Both (mt10argyll and wasz)
Really appreciate the advice, you were both spot-on. The regulator had the 'boxster stop' in place. Was a 5 minute job and its all sorted.
I love jobs like that: initially appears tricky, turns out to be simple and with immediate results
Thanks again!
wasz
PostPosted: Fri Feb 16, 2018 9:42 pm    Post subject: Reply with quote
Happy to help, I have had loads of help on here in the past!
