996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Dave Smith
2004 Porsche 996 Targa
PostPosted: Sun Feb 11, 2018 3:29 pm    Post subject: Clutch pedal not fully up Reply with quote
Our 911 finally saw the 2018 light today after 2/3 months stuck in the garage. Had a walk planned so seemed a great opportunity to take it out.
Its been used to this lack of use each winter and never beena problem. However today when I took it out the clutch pedal was partially down and stayed down. I tried pumping the clutch but made no difference, I could still change gear OK so decided to go for the planned drive anyway and see if this helped.
About 15 minutes later my left foot was pleasantly surprised to be hit by the clutch pedal pinging up and returning to normal. Was fine for the rest of teh drive to the walk, and when we drive home.
My only guess is that this is the first really cold winter for a while, and its not been used for slightly longer than usual.
Just wondered what might be going on?
And yes, I know I should be using the car more often Very Happy
alex yates
PostPosted: Sun Feb 11, 2018 3:32 pm    Post subject: Reply with quote
Sounds like it may have been a sticky master or slave cylinder Dont know
Will most likely be ok now.
Norfolk & Idea
PostPosted: Sun Feb 11, 2018 3:42 pm    Post subject: Reply with quote
Pop an orthopeodic shoe on your left foot. It'll give a bit more 'stroke' That'll sort it... Smile
2012 997.2 Turbo Basalt Black. Bit of a 9E ing.
2008 Ducati 1098R (Track)
2016 Macan GTS
2008 Vito Sport- Household Star!
2018 Ducati Panigale V4S (Track)
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sun Feb 11, 2018 9:05 pm    Post subject: Reply with quote
I'd gamble clutch master cylinder.
toddy2
PostPosted: Mon Feb 12, 2018 6:23 am    Post subject: Reply with quote
I had a similar issue a couple of weeks ago. Master slave was the issue, cheap fix
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944
Dave Smith
PostPosted: Mon Feb 12, 2018 8:32 am    Post subject: Reply with quote
Thanks all.
Will keep an eye on it and try and get the car out a bit more as the weather improves. Its being serviced in June so will mention it then if nothing happens in between.
