997 : 2004- 63
Carrera SC : 1977-1983 3
Cayman : 2005- 23
Macan : 2014- 7
PostPosted: Fri Feb 09, 2018 4:27 pm    Post subject: Steve Wright's Serious Moddin' - Xtrons Double Din install Reply with quote
My son's bought me an Xtron double din head unit for Christmas and it got delivered the other day. Seeing as I was quiet at work yesterday and today I thought I'd get on with the job of fitting it in the cavity left by my HVAC and single Din Becker unit..
I bought the connect2 trim and cage kit specifically for the 996 without cup holders (at a cost of £30) off eBay.
So today I set myself the task of installing it, but I knew fine well there was no chance it was going to be a simple installation and was ready to fire up my milling machine to pull me out a pickle. Seeing as it's Friday afternoon and Steve Wright's on the radio serious jockin', I thought I'd do a quick 'serious moddin' thread (again) before heading off to the boozer to meet the lads for a couple.
First job was to see what fit were and what didn't. I was quite impressed that from a wiring point of view nearly everything was just plug and play. I also had to buy a radio antenna adapter to convert from iso to din for the aerial - £1.20 off ebay, but everything else just plugged straight in and worked. The unit can with a wring harness to connect the Porsche Din plugs for power, speakers, etc. into the Xtrons unit.
! started off attempting to do the job in situ and started by cutting out the centre piece that originally ran between the head unit and HVAC. Also the middle screw holes needed lobbing off for the width of the unit to fit.
You can see the Xtrons harness plugged in here and also the centre bar and screw holes that needed removing.
Easily chopped out with an old hacksaw blade.
No surprise, the standard Din cage supplied by Connect2 wouldn't go anywhere near the aperture.
So at this point, I thought best to remove it from the dash and get in my Engineering cave and fire up the tools.
First unclip the switch gear housings from either side and disconnect all the plugs. Then you can see the 4 torx screws holding the centre piece in place.
Doesn't half leave a baggy cavity once removed.
That's better. A nice warm toasty workshop and the kettle on the boil. Time to assess what next.
Embarassed Just noticed on the above photo I'd already added the side adjustable locking plates that came with the connect2 kit that hold the head unit securely in the cage. So I'll just put this photo here so we don't miss 'owt.
Right, where were we. Ah, the connect2 trim designed for double din units. Did it fit? Did it 'eck. The aperture in the trim was much smaller than the outside of the 'standard size' head unit. If it was meant as a trim that overlaps the front, then it's still too deep and wouldn't look right. Either way, I wanted my trim to fit round the outside of the unit and the screen protrude a mm or so once finished.
You can see here the depth of the trim and also how it overlaps that much, it restricts access to the touch screen buttons on the left.
To be precise, the trim needed 3.4mm taking out the height and 5.4mm taking out the width to make it fit. We'll come back to that later.
Next job was to get the centre piece and machine out to enable the cage to fit. The air ventilation shrouds were still fitted and needed removing for me get be able to clamp on the miller, so one of my favourite tool came out to prevent any brittle plastic clips breaking - the Hair Dryer. I good warming up around the clip positions stops any breakages and usually makes the parts come apart easier.
Now on to the miller to machine out any material preventing the cage fitting.
Shazaam......nice and straight all the way up.
And a perfect fit.
Early dress rehearsal but only halfway.
Unit was protruding further out than I wanted so a small adjustment to the side plates dropped back a few mm to my desired position.
Next job was to machine the aperture in the trim to allow it to fit over the front of the HU. Not easy maching something so soft so had to do one face at a time. Normally I'd have just written a program and cut the lot out in one go.
All done and ready for trying on.
Yes, I think we're starting to get excited.
Once fit for size it now gave me a position I could lock the cage in. There was no support along the top for the cage and fortunately I'd not machined to top holes out as they weren't in the way so I used them for clamping an Aluminium bar along the top that would not only add strength but also give me something really firm to lock the cage against.
Cage now locked in and ready for fitting back in the car.
Back in position, ensuring all the plugs are in the right places for the switch gear and head unit. 4 torx back in and locked up.
Everything now back in position, plugged in, trim fitted and ready to roll.
This thing's awesome. I can even watch movies on it. Android based so can do anything with it a phone can do. Unbelievable how much these things are nowadays.
Total cost was:
Xtrons TL702P £140 - https://www.ebay.co.uk/itm/XTRONS-TL702P-7-Android-6-0-Double-DIN-Sat-Nav-Car-GPS-Stereo-DAB-Radio-WiFi-/272479900490
Connect2 fitting kit £30 - http://www.ebay.co.uk/itm/CT23PO02-Black-Double-Din-CD-Fascia-Panel-Kit-For-Porsche-911-TYP996-1998-2004/350615577362
ISO to Din aerial adapter £1.20 - https://www.ebay.co.uk/itm/CAR-AERIAL-ANTENNA-ADAPTOR-RADIO-STEREO-ISO-to-DIN-SONY-JVC-PIONEER-CT27AA01/281280234548
Next serious modding will be triple USB head unit interface......possibly in the centre arm rest glovebox.
Right, were's that boozer Drinkers
Almost forgot. Couldn't post the thread without showing off me dog on his hols Grin
Open Youtube Page
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Fri Feb 09, 2018 4:39 pm    Post subject: Reply with quote
That is a very clinical install, nicely done
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON TWITTER
FRP
PostPosted: Fri Feb 09, 2018 5:14 pm    Post subject: Reply with quote
Brilliant. If only I had such skills. Machines. Or even a workshop. Great work
2002 996tt x50 manual in bassat black - 9eXX
wildej
PostPosted: Fri Feb 09, 2018 5:18 pm    Post subject: Reply with quote
Looks smart that Alex, I'm tempted to get rid of PCM3 in mine as it's utter shite as a system.
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
EGTE
PostPosted: Fri Feb 09, 2018 6:01 pm    Post subject: Reply with quote
Nice one, Alex Thumb
You should set up a business doing this (at forum rates) Very Happy
Halcyon
PostPosted: Fri Feb 09, 2018 6:36 pm    Post subject: Reply with quote
I agree with you Alex - that "Connects2" trim kit is pretty bad. I ended up not using the cage as I couldn't get it to fix securely.
I used the cage that can with the HU and adapting the trim to fit in the end.
Happy with the results in the end, but it ain't no "plug n play" nooo
996.2 Carrera 4 Convertible Tip
toddy2
PostPosted: Fri Feb 09, 2018 7:58 pm    Post subject: Reply with quote
Excellent work, I wish I had the time and skills. Mines booked in for next Wednesday. After recommendations on here I've gone for the metra kit. Can't wait Very Happy
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944 (Sold)
 Filesize:  1.92 MB
 Viewed:  5425 Time(s)
ragpicker
Reims
PostPosted: Fri Feb 09, 2018 8:23 pm    Post subject: Reply with quote
Great work there dude! The end result looks superb! Thumb
kurlykris
PostPosted: Fri Feb 09, 2018 9:32 pm    Post subject: Reply with quote
Top work Alex, you could get a job doing this engineering malarky Very Happy
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
BHZ661
PostPosted: Sat Feb 10, 2018 7:37 am    Post subject: Reply with quote
Fantastic work Alex looks amazing thumbsup
kas750
Shanghai
2006 Porsche 911
PostPosted: Sat Feb 10, 2018 8:55 am    Post subject: Reply with quote
Brilliant job Alex. thumbsup
pzero
PostPosted: Sat Feb 10, 2018 9:37 am    Post subject: Reply with quote
Cool piece of kit and cool fit Alex. Excellent demo with the handsome hound on the beach.
New997buyer
Banned
PostPosted: Sat Feb 10, 2018 10:38 am    Post subject: Reply with quote
Great piece of work thumbsup
matt_SM
PostPosted: Sat Feb 10, 2018 2:05 pm    Post subject: Reply with quote
That looks really tidy, nice job Thumb
CarraraWhite
2011 Porsche 991 Carrera
PostPosted: Sun Feb 11, 2018 11:20 am    Post subject: Reply with quote
+1
991Turbo, dont need the S
PostPosted: Sat Feb 29, 2020 12:08 pm    Post subject: Reply with quote
Update: My xtrons unit gave up emitting any sound a few months ago. Everything else works fine but no sound, making it pretty pointless nooo
Regardless of that though - the tech game is one big con and once you're 18 months down the road its obsolete anyway and developers cease doing updates.
So last weekend I bit the bullet and bought a new Xtrons head unit. Did this as they're only cheap for what they are and wanted as easy plug n play as I could get, so needed to be same size, sockets, etc. As usual, you can install any Apps you want: Waze, Apple car play, Spotify, BBC iPlayer, etc. Also has multiple inputs for various car gadgets - tyre pressure, OBDII, steering controls and so on.
Xtrons TSD700l - £149.99:
https://www.ebay.co.uk/itm/7-Android-10-0-Double-DIN-DSP-Car-Radio-Stereo-GPS-Head-Unit-SAT-NAV-WiFi-DAB/333050158639
https://xtrons.co.uk/double-din-android-10-quad-core-2gb-ram-16gb-rom-tsd700l
Will post any updates on issues, benifits, etc.
thumbsup
996lee
PostPosted: Sat Feb 29, 2020 8:12 pm    Post subject: Reply with quote
Liking the looks of that
Cool
I've previously been tempted by other double din units but I like the way this doesn't have a brand splattered across the front
So looks very OE Thumb
2001 Carrera 4 aero all the way!!
sparticle
PostPosted: Tue Mar 24, 2020 12:01 pm    Post subject: Reply with quote
thumbsup
ALEX,
You probably haven't read my prject car post and the Audio woes. We are currently looking at https://www.ebay.co.uk/itm/Universal-7-Android-10-0-Car-Stereo-Double-Din-Head-Unit-Radio-GPS-DVR-Camera/333435604068?hash=item4da24f8c64%3Ag%3AFikAAOSwvMBd8ed0&LH_BIN=1 this unit and I believe it is the same one you were looking at. We don't have access to the kind of workshop and machines you have. Do you know of a facia trim kit that will work with this unit and possibly keep the cup holder?
Also when you relocated the AC unit to replace the CD Tray did that require any special machining?
Any advice is appreciated as we are about to do this minus the factory BOSE AMPS which were blown due to the vehicles electrical mishaps historically.
Spart
PostPosted: Tue Mar 24, 2020 12:26 pm    Post subject: Reply with quote
The facia kit above also is available for the cup holder version. Search hvac on here and you'll see my thread on the relocation of that.
sparticle
PostPosted: Tue Mar 24, 2020 3:36 pm    Post subject: Reply with quote
Are you talking about the Connects2 facia? that needed a milling machine to make a decent job of it?
Spart
