997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Thu Feb 08, 2018 9:00 pm    Post subject: Rev range data Reply with quote
How do you interpret the data screenshot below? I've read you check against engine hours and number of ignition but this screenshot does not seem to show the data in the same way..
 Filesize:  670.66 KB
 Viewed:  1365 Time(s)
wasz
PostPosted: Thu Feb 08, 2018 9:11 pm    Post subject: Reply with quote
http://www.911virgin.com/porsche/rev-range-information/
http://www.durametric.com/usedporschebuyersguide.aspx
Agree it looks odd.
asterix_the_gaul
PostPosted: Thu Feb 08, 2018 9:14 pm    Post subject: Reply with quote
yes that's exactly what I read before posting : I was under the impression you would get number of ignitions not a decimal??
Last edited by asterix_the_gaul on Thu Feb 08, 2018 9:35 pm; edited 1 time in total
asterix_the_gaul
PostPosted: Thu Feb 08, 2018 9:20 pm    Post subject: Reply with quote
maybe I'm looking at the wrong part, that Was The live data feed..
Magic919
PostPosted: Fri Feb 09, 2018 8:00 am    Post subject: Reply with quote
They look like ECU adaptations to me.
997.2 C2S PDK
997.2 C4S PDK
Marky911
Watkins Glen
PostPosted: Fri Feb 09, 2018 9:10 am    Post subject: Reply with quote
Yes that isn't the normal over revs page.
You should just see total operating hours, then range 1 with number of ignitions and the hour the last one occurred and then the same for range 2.
Some cars have tens of thousands range 1s, which is just from bumping the rev limiter.
Range 2 are the "bad" ones, which are over the rev limiter.
As the guides probably say, divide by 400 for a rough calc for seconds on the limiter.
So 2800 ignitions would be about 7 seconds.
You need to actually find your over rev menu first though. Grin
Later cars, 997 onwards had 6 ranges. The earlier cars only had 2.
PostPosted: Fri Feb 09, 2018 7:21 pm    Post subject: Reply with quote
They are NOT over revs .. they are the fuel adaption figures .
Vehicle data and range 1 / range 2 on a 996 when useing a tester is what you want , those figures are from the DME section and actual values .
asterix_the_gaul
PostPosted: Fri Feb 16, 2018 8:53 pm    Post subject: Reply with quote
Found the correct screen to get rev range data like the one in the diametric link a few posts earlier. No range 2 over revs not too much range 1 and all thousands of hours ago so happy days. Thanks all!
